20 Most Recent
BitTorrent uTorrent Questions & Answers
How do i uninstall
click start control panel add or remove programs or uninstall a program this may vary depending on your operating system scroll to see if the program is listed select uninstall or it might have its own uninstaller
click start all programs look for program select it and see if it has the uninstall capability
hope this helps
How do i disconnect
Check your system tray (near the time on your task bar.) There will be an icon for uTorrent. Right click on it and select Exit. You will then be prompted to confirm your decision.
If this is not what you mean, please clarify!
I have 2 large torrent files downloading in
Your downloads are to be found when you log in again to Bit Torrent as long as they are still in your computer in the same place. Before you format find your downloads location and the location of the Torrent file.
Copy them to a memory stick and then replace them in the same folder after format. Re-install bit comet and log on and they should be in your list. Fully install Bit Comet and Emule if you were using it before you start but replace the files before you do that.
NO VOLUME WHEN I BURN MOVIES
Make sure you are adding the audio_ts folder as well if you are downloading a DVD rip. You find instructions using google.
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
