20 Most Recent
Canon LASER CLASS 2050P Questions & Answers
Check cover/cartridge when there's a new cartridge in it
Ignore it. Printer cartridge manufacturers and cartridge people post these message so they can con you into buying more cartridges. If it prints, just keep on going. If it doesn't print go to the printer manufacturer's site - it would help me if you had given details there - and see if there is a new driver. If so download it and install it on your computer. If not, uninstall the current driver COMPLETELY and then reinstall it. Files get corrupted for no good reason - that's the second choice.
When the fax machine says
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
I need drivers canon laser
Windows 7 is designed to automatically recognize and download the drivers for printers, copiers, cameras, phones, etc. as soon as they are plugged in. If you plug in your Canon and you do not see a little window pop up on the bottom right corner of your screen, it is possible that there is something wrong with either the canon or maybe your connection. And if the window does pop up, the driver should download automatically.And last but not least, you can always go to the Canon website click on support and find the driver there.
Tengo una Copiadora Canon IR 1023, a cada rato se atasca el papel, se queda al pasar por el rodillo del termico no sale, se arruga y atasca.
Si tu copiadora Canon IR 1023 se atasca constantemente con papel y se arruga al pasar por el rodillo t?rmico, aqu? hay algunas soluciones y pasos que puedes intentar:
1. Verifica el tipo y la calidad del papel: Aseg?rate de utilizar papel de calidad y del tipo adecuado para tu copiadora Canon IR 1023. Utilizar papel de baja calidad, h?medo, arrugado o demasiado grueso puede causar atascos.
2. Limpia el rodillo t?rmico: Si el rodillo t?rmico est? sucio o presenta residuos de tinta o polvo, puede provocar atascos de papel. Apaga la copiadora, desench?fala y deja que el rodillo t?rmico se enfr?e por completo. Luego, utiliza un pa?o suave y limpio ligeramente humedecido con agua para limpiar cuidadosamente el rodillo t?rmico. Evita usar productos qu?micos agresivos o solventes, ya que pueden da?ar el rodillo.
3. Revisa las gu?as de papel: Aseg?rate de que las gu?as de papel est?n correctamente ajustadas seg?n el tama?o y la orientaci?n del papel. Las gu?as mal ajustadas pueden causar atascos y arrugas en el papel. Ajusta las gu?as cuidadosamente para que est?n en contacto suave pero firme con el papel.
4. Verifica y limpia los sensores de papel: Los sensores de papel son peque?os dispositivos que detectan la presencia y el movimiento del papel dentro de la copiadora. Si estos sensores est?n sucios o defectuosos, pueden causar atascos y otros problemas. Consulta el manual del usuario de tu copiadora para localizar los sensores de papel y c?mo limpiarlos adecuadamente.
5. Realiza un mantenimiento regular: Programa un mantenimiento regular con un t?cnico autorizado de Canon para verificar y limpiar los componentes internos de la copiadora. Un mantenimiento adecuado puede ayudar a prevenir atascos y otros problemas.
Si los problemas de atascos de papel persisten a pesar de seguir estos pasos, ser?a recomendable contactar a un t?cnico especializado de Canon o al servicio de atenci?n al cliente de Canon para obtener asistencia adicional. Ellos podr?n proporcionarte soluciones espec?ficas para tu modelo de copiadora Canon IR 1023 y brindarte un soporte m?s detallado.
What should i do to fix this error? Canon i-sensys mf 9220 showing system error E000003 on screen
What is the Canon i-sensys mf 9220 system error E000003?
The Canon i-sensys mf 9220 system error E000003 is an error that can occur when you're trying to print documents. Basically, it means that the printer can't communicate with the computer. This can be caused by a number of things, but the most common cause is a problem with the USB cable.
How to fix the Canon i-sensys mf 9220 system error E000003?
If you're getting this error, the first thing you should do is check the USB cable. Make sure that it's properly connected to both the printer and the computer. If the cable is loose or damaged, try replacing it with a new one.
I hope this helps!
