20 Most Recent
Technics SA-DA8 Receiver Questions & Answers
Sa-da8 overload and off
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
Sa-Da8 Overload and power off
you mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Technics RS-BX501 cassette deck door won't open
If you feel confident doing so, you could attempt to open the cassette deck and physically examine the gears to check for damage or debris that might be obstructing them.
But do remember that there are risks involved when opening electronic equipment, especially if you're not used with doing this kind of work. If you're not sure you can do this securely, it would be preferable to get assistance from a qualified audio equipment repair specialist.
