http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hewlettpackard_1_printer_product_list.html hope it helps
select file in the top left hand corner then select print preview from the drop down list there should be another drop down list in top left hand corner with percentages
30%
40%
50%
etc....... this is on a web page
the same should be on the page if you have made a word document
if you are using word open up word select view from the drop down list select toolbars select standard formattingalso open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in also next to that will be a drop down list with all sizes you can change the sizes of text open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases if you are using a word document to open it on the top select the format tab open it then select font you can change your settings there also across the left you will see a stencil and an A which have drop down lists of color changes for background and printhope this helps
8 questions posted
5,069 Questions
2,066 Questions
1,757 Questions
1,195 Questions
1,096 Questions
