20 Most Recent
Epson Stylus Photo RX520/RX530 Questions & Answers
Epson how to install
Are you running Windows or AppleMac If so:
1. Install the programs off the CD, which I assume came with the printer.
2. No CD... Go to
www.epson.com or .co.uk , click on SUPPORT/printers, choose your printer and operating system and install the neccessary drivers
If you are using the BEST O/S on the planet...LINUX:
Click on SYSTEM/ADMINISTRATION/PRINTERS AND + ADD (A PRINTER).
I am getting gray background when printing pictures why?
Can you see the entire page when you issue the PRINT command. Are you using Windows. If you are trying to print a picture from a website, you firstly need to take a snapshot of the entire page by holding down the left ALT key and pressing the key marked PrintScreen (usually located below F10,11,12) on your keyboard. Then use an Image editor to cut out the picture and then PRINT it.
Printer driver
Http://www.driveridentifier.com/ I highly recomend you this freeware software since i'm pretty sure it can get you most of the drivers. However, in order for this tool to find the drivers you're looking for, you have to run it in the computer you need the drivers for.
I have a EPSON Stylus
Hi, welcome to FixYa.
Usually, most printer driver need to be installed first BEFORE plugging the printer itself to the computer. Are you sure you have installed the driver before plug the printer? Or perhaps you do the otherwise?
If you installed the driver after plug in the printer, you must remove the driver first, unplug the printer then reinstall the driver and follow the instruction on the installation.
My copies and scans are coming through black as
If you try scanning with the flatbed open, can you see if the bulb lights up during scan? If not, (or if darker than usual) then your bulb is no longer good on the scanner. If the bulb is bad, it would most likely be cheaper to replace the whole scanner versus paying to repair/replace the bulb.
If the bulb is fine, I would perform a hard reset on the device. To do this: Press and HOLD all following buttons: Power, Load/Eject, Stop, B&W, Color. RELEASE BUTTONS. After this printer turns on, you'll see "Init eeprom" on printer screen. Press Color button to clear protection counter.
How to fix error code E04
Open the printer (like to change the cartridges) and look for any bits of paper or other material that may be between the rollers that may have torn off of some printer paper and just collected there. You may possibly be able to clean any stuck paper or other stuff like lint with a thin piece of card stock.
Epson Projector S05 text is shodow
If the text on your Epson EB-S05 projector is appearing blurry or shadowed, there are several possible causes and solutions to consider:
- Check the focus: Make sure the projector is in focus by adjusting the focus ring. If the text still appears blurry, try adjusting the position of the projector or the screen.
- Check the resolution: If the input resolution of your projector does not match the native resolution of your display or screen, the text may appear blurry or shadowed. Check the resolution settings on both your projector and your device to make sure they match.
- Check the cables: If the cables connecting your projector to your device are old or damaged, they may cause interference or display issues. Try replacing the cables with new ones and see if that improves the text clarity.
- Check the lamp: If the lamp on your projector is old or damaged, it may cause the image to appear dim or blurry. Check the lamp hours and replace the lamp if necessary.
- Check the settings: Make sure that the brightness, contrast, and other settings on your projector are properly adjusted. Experiment with different settings to find the optimal image quality.
If none of these solutions work, it may be necessary to consult the Epson customer support or to take the projector to a professional technician for repair.
Epson Artisan 835 waste pad cleaning or replacement, how?
The Epson Artisan 835 waste pad is located in the printer's waste ink compartment and is designed to absorb any excess ink that is generated during the printing process. Over time, the waste pad can become saturated with ink, which can cause issues with the printer's performance.
To clean or replace the waste pad on an Epson Artisan 835 printer, you will need to follow these steps:
- Turn off the printer and unplug it from the power source.
- Open the printer's cover and locate the waste ink compartment.
- Carefully remove the waste pad from the compartment.
- Clean the waste pad with a damp cloth, or replace it with a new one if it is heavily saturated with ink.
- Reinstall the waste pad into the waste ink compartment.
- Close the printer cover and plug the printer back in.
It's important to note that this process can be messy and you should use gloves and old clothes to avoid getting ink on your hands or clothes. Also, some printer models may have a different process to access the waste pad, you might need to consult the printer's manual or Epson website to know more about your specific model.
Is there anyway to connect my Chromebook to my Epson EMP-83H projector when my Chromebook only has either a USB or 2 Type -C ports?
Yes, there are a few ways to connect your Chromebook to an Epson EMP-83H projector even if your Chromebook only has a USB or 2 Type-C ports. Here are a few options you can try:
- Use a USB-C to HDMI adapter: If your projector has an HDMI input, you can use a USB-C to HDMI adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a USB-C to VGA adapter: If your projector has a VGA input, you can use a USB-C to VGA adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a Chromecast or similar device: You can use a Chromecast or similar device that can be connected to the projector via HDMI, this device will let you mirror your Chromebook's screen on the projector wirelessly.
- Use Google Meet: If the projector have internet connectivity, you can use Google Meet on your Chromebook to conduct a video call, you can share the screen of your Chromebook with the projector and use it as if it were connected through cable.
- Use a USB-C to USB adapter: If your projector has a USB input, you can use a USB-C to USB adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to use the USB function on the projector, such as using a USB drive to display content on the projector.
It's worth to mention that, Before buying any adapter or device, make sure it's compatible with your projector, and also check the resolution and refresh rate supported by the adapter to ensure that it can meet your needs. Additionally, it's always best to check the instruction manual of your projector and the adapter to ensure that you are using it correctly.
Where can we download Epos Tep 220mc thermal
Hi you can use the Epson TM-88 Driver,
the following link will take you to the Epson download library just check which is the right driver for your operating system and hopefully it will work (there are different types if you are not sure which one is best trial and error is a good option in this case :) ), the manufactures
brochure has more details about this printer it is worth keeping and reading if you own the printer good luck.
Multi media audio controller out of date. No audio
ust
download this software,no need search engine,no more tired of looking
anywhere...instantly,it will be in your laptop for several
minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Epson Printer Technical Support pHoNe ~#{+1-855+SCAMMER 67] Number USA
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Epson Printer Customer Service pHoNe ~@{+1-855@SPAM 67} Number USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
EPSON PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OO*DELETED 69} RITA USA
EPSON PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OODeleted 69} RITA USA
