20 Most Recent Albatron LNX-21TIS-3 Television Questions & Answers
0answers
2answers
Lcd32880hdf 10 months old. When switched on the
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
7/24/2012 8:41:16 PM • Albatron... • Answered on Jul 24, 2012
0answers
USER /MANUAL/ NEEDED FOR ALBA LCDW16HDFP . NEEDED TO SET
I need to tune channels in Alba 15in flat screen tv, lost the manuals
5/24/2010 5:11:55 PM • Albatron... • Answered on May 24, 2010
Albatron LNX-21TIS-3 lcd tv does not power
I just fixed my Albatron LNX-21TIS-3.
The power supply had gone out so I took an ATX computer power supply and changed the plug.
The Albatron runs on 12V and 5V just like the ATX computers. The trick is to find a power supply that is the same size then you just modify the wires on the power plugs to match up.
3/5/2009 2:18:58 AM • Albatron... • Answered on Mar 05, 2009
How can I find whats on next on my alba tv remote ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
7/27/2016 2:19:14 AM • Albatron... • Answered on Jul 27, 2016
Powers up but get no signal sign
Use the input button or menu button to change the input to cable.
11/30/2013 1:56:42 PM • Albatron... • Answered on Nov 30, 2013
0answers
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
6/11/2012 4:48:17 PM • Albatron... • Answered on Jun 11, 2012
0answers
Blue light flashing
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section. Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multi-meter to check the continuity or shorting in components, if so detach from circuit and test. If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly, the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
1/20/2012 12:18:31 PM • Albatron... • Answered on Jan 20, 2012
When i turn my t.v on it comes on but goes off after 15 seconds or so the screen goes black and you can here sound then it turns off can you help
Hello,This issue is related to a power problem in as much as the TV turns off on it's own.The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply boardYou can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.I wish you the best of luck.Regards.
1/5/2012 9:53:56 PM • Albatron... • Answered on Jan 05, 2012
2answers
Claves radox 842
Clave de una tele gu?a para programarla con un control remoto radox 842.
12/6/2022 2:48:45 AM • Televison &... • Answered 4 hours ago
Model itvs-750b fell off stand and now wont power on
I would say transformer probably broke in fall, but could be any electronic device. By the time you ask someone to fix it, you might find it's cheaper to buy a new one. Sadly.
12/5/2022 8:54:27 PM • Televison &... • Answered 10 hours ago
Televison & Video Logo
11 questions posted
Top Albatron Televison & Video Experts
Marvin
Marvin
Are you an Albatron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Albatron Televison & Video
Most Popular Question
lcd32880hdf 10 months old when switched
  • Televison & Video
