20 Most Recent
Xerox Phaser 3100MFP Questions & Answers
Data flash error
Please can you tell where are you exactly getting this error . and also mention the Application name in which you got this
How to reset Xerox Phaser 3100 to factory settings?
First you have to enable the admin mode:press and release: (down arrow) * #on SOS1 change the 8th bit to 1 (counting right to left)ie: 00100001 to 10100001 {press OK to confirm}Now the admin menus are enabled. To <Erase all. Reset to default configuration>press (and release): (down arrow) #7
Xerox Workcentre 7535 LED's flashing repeatedly when powering up
Hai this is Arun. If your motherboard gets power but the computer not starting then there are two solutions :
- Unplug the wire that is coming from the power switch to the motherboard & plug it again.
- If it is still not starting, then remove your CMOS battery and insert it again in the motherboard.
Hope these steps may solve your problem.
Thanks.
