20 Most Recent Canon LBP2900 Questions & Answers
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
4/16/2021 2:46:52 AM • Canon LBP2900 • Answered on Apr 16, 2021
2answers
After printing first page second page printing becomes jammed every time and then I have to free jam manually
I get this problem sometimes. The quick answer is to put a large 'bulldog clip' around the stack of paper, and feed in one sheet by hand. When the sheet is almost printed feed in the next sheet. The long term solution often is to service the 'rubber' paper feeds that get covered in dust. Use a damp cloth and press against one roller at a time, rotating a bit at a time. Not as easy as it sounds! Then use a bit of fine 'sand' paper to remove the shiny surface on the roller(s) and wipe clean again.
9/2/2016 5:17:40 AM • Canon LBP2900 • Answered on Sep 02, 2016
2answers
I had install all the available drivers for Canon
The 2900 driver should work for the 2900E. The problem may be that there is a:
Canon SENSYS i-LBP-2900, and
Canon Laser Shot LBP-2900
Which printer do you have? Which driver did you download?
You can try this site if you can confirm your model:
http://software.canon-europe.com/index.asp
See here for Linux compatibility for Canon products:
http://www.canon-europe.com/Support/software/linux/
Trust this is helpful. Please vote. Thank you. :)
2/14/2016 8:50:35 AM • Canon LBP2900 • Answered on Feb 14, 2016
How to repair paper jam
Hello, here is a youtube.com demonstration on how to clear jams on the printer. Fixing Paper Jam canon lbp2900b
10/26/2015 8:20:38 PM • Canon LBP2900 • Answered on Oct 26, 2015
DOWNLOAD DRIVER FOR CANON LBP2900
Hi sparexhg:
Your driver can be found here:
http://support-sg.canon-asia.com/P/search?category=Laser+Printers&series=Monochrome&model=LBP2900&menu=Download&filter=0
You will need to select your versions of Windows before downloaing your driver.
Trust this helps. Please vote.
9/8/2015 3:44:05 AM • Canon LBP2900 • Answered on Sep 08, 2015
2answers
Usb port is not recognising the printer
Turn every thing off including the printer and the computer. then turn on the PC then turn on the printer then plug in the printer after it is on.
4/17/2015 6:47:14 PM • Canon LBP2900 • Answered on Apr 17, 2015
I have a pixma pro 10, and I am running windows 7. How can I disable the ink monitoring function? How can I force the printer to print without regard for ink levels?
Go to control panel, add or remove programs and look for a program that may be monitoring it, uninstall OR How To Disabling the Printer Ink Monitor for Canon
3/15/2015 9:07:00 PM • Canon LBP2900 • Answered on Mar 15, 2015
I need the port of canon LBP2900
6/16/2014 1:25:25 PM • Canon LBP2900 • Answered on Jun 16, 2014
I required Canon LBP2900B printer
Its a USB printer.
5/12/2014 11:13:47 AM • Canon LBP2900 • Answered on May 12, 2014
Canon image class 3010 slow printting
Hi there: The main cause of slow printing is due to a bad print cartridge. To troubleshoot this please remove one of your cartridges and see if your printing speeds up. If that does not work. Replace the cartridge and remove the other cartridge. If your printing speeds up. That print cartridge is at fault.
4/19/2014 2:19:21 AM • Canon LBP2900 • Answered on Apr 19, 2014
WHAT IS THE RATE OF NEW SCANNER UNIT FOR CANON
The best is : You can go for CANON SCAN LIDE for better performance.
3/30/2014 4:45:11 AM • Canon LBP2900 • Answered on Mar 30, 2014
Canon lbp2900 sensys
Check the below web link to download. http://www.canon-europe.com/Support/Consumer_Products/products/printers/Laser/i-SENSYS_LBP2900.aspx >> Select >> Software (drivers and applications) >> Select Operating system in drop down list (Ex: Windows 7 32bit or 64bit)) >> Select Preferred Language (Ex: English) It will show the result of available software list and download it.
3/30/2014 3:11:38 AM • Canon LBP2900 • Answered on Mar 30, 2014
My canon lbp2900 printer is not print any document
Plenty of places to look at as you give me no clues! Is the power light on? If not check the power lead and power point. Is the toner OK? Is the paper OK and the paper feed working? Does your computer show it is linked to the printer? You can do troubleshooting at the Canon website http://www.canon-europe.com/Support/Consumer_Products/products/printers/Laser/i-SENSYS_LBP2900.aspx
1/29/2014 4:20:23 PM • Canon LBP2900 • Answered on Jan 29, 2014
Lbp 2900b install
1/4/2014 2:29:14 PM • Canon LBP2900 • Answered on Jan 04, 2014
Incorrect port message with canon lbp2900
Look in the Printer Properties for a Virtual USB port; an LPT1 port is a parallel port, seldom included on newer computers. The software CD should have installed a USB port, and associated the printer with that port.
12/13/2013 3:37:24 PM • Canon LBP2900 • Answered on Dec 13, 2013
Does't print on half paper cartrese was ok
Please send me details of printer model, make & type @[email protected]
11/2/2013 6:46:16 PM • Canon LBP2900 • Answered on Nov 02, 2013
Canon laser printer paper jam solution
printer of hitar was not right packing open the printer and again packing
10/6/2013 5:59:39 AM • Canon LBP2900 • Answered on Oct 06, 2013
How do I remove a print job that has already been
Click on the printer icon next to the time& then cancel print
9/2/2013 4:14:59 AM • Canon LBP2900 • Answered on Sep 02, 2013
Computers & Internet Logo
54 questions posted
Top Canon Computers & Internet Experts
old marine
old marine
OfficeServiceAjnc
OfficeServiceAjnc
kdigby
kdigby
Level 1 Expert
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Canon Computers & Internet
Most Popular Question
required canon lbp2900b printer
  • Computers & Internet
