20 Most Recent Nokia Inc 002L103 N97 Touch Screen phone Questions & Answers
Contact your phone service provider to unlock the SIM card or have your SIM card replaced. Your phone service provider should have your PUK code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nokia Inc... | Answered on Aug 18, 2011
first check cell phones battery point.if fault not solve try to hard reset it when u reset it u r lose ur phone data.suru1414_0.jpg
Nokia Inc... | Answered on Feb 10, 2011
its because of touch screen IC which is conected with mobile CPU is short. it happen because of heavy use of touch screen with finger either then its pen stick. because in human body so many types of electron current is flowing and its enough to damage small IC of Touch Screen.
Nokia Inc... | Answered on Nov 03, 2010
You cant block icomming calls from some specific numbe with Nokia 301, but as a compromise solution would be to silence it, i.e. to play silence, when unwanted number is calling. You can create group unwanted, add your unwanted numbers, download some silence tone and assign this tone as the ringtone for this group.
Nokia Cell... | Answered on Sep 22, 2020
My Nokia hs-36w is behaving exactly the same.
Nokia Cell... | Answered on Aug 30, 2020
Impossible to forget a security code to a phone you are using dozens of times a day!
Codes NOKIA 1110i, how to - HardReset.infowww.hardreset.info > devices > nokia > nokia-1110i > codesHere you can find all secret codes for NOKIA 1110i. ... Click here and find out more information about secret codes. ... If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# ... 12345 This is the default security code.
Nokia Cell... | Answered on Aug 29, 2020
The default security code is 12345 for most Nokia phones. If you enter an incorrect security code five times in succession, the phone ignores further entries of the code. Wait for five minutes and enter the code again.
Nokia Cell... | Answered on Aug 24, 2020
Hard Reset Nokia 5310 with special code / master key / shortcut / secret key: Try to type: *#7370# and it will ask the security code of Nokia 5310, press 12345.
Nokia 5310 Hard Reset - UnlockandReset.com'Hard Reset ...
www.unlockandreset.com > nokia-5310-hard-reset
Hard Reset NOKIA 5310 XpressMusic, how to - HardReset.info
www.hardreset.info > devices > nokia > nokia-5310-xpressmusic
How to restore defaults in NOKIA 5310 XpressMusic? The following ... Factory Reset · How to Hard Rest NOKIA 3310 2017 - Reset Code in NOKIA - video ...
Codes NOKIA 5310 XpressMusic, how to - HardReset.info
www.hardreset.info > devices > nokia-5310-xpressmusic > codes
Codes NOKIA 5310 XpressMusic · *#06# for checking the IMEI (International Mobile Equipment Identity). · *#7780# reset to factory settings. · *#67705646# This will ...
Hard Reset for Nokia 5310 XpressMusic - HardReset24.com
hardreset24.com > instruction > hard-reset-for-nokia-5310-xpressmusic
1. Power up the phone. Hard Reset for Nokia 5310 XpressMusic 2. Open the dialer, enter this code into it - *#7370 ...
Nokia Cell... | Answered on Aug 15, 2020
https://www.howtogeek.com/howto/20703/run-android-on-your-windows-mobile-phone/The Nokia Lumia was replaced by Microsoft. It is a discontinued, unsupported phone. And, although a Windows Phone may be able to run an android OS, the procedure well might be specific to the particular phone. The following link point to whom you might consult regarding the matter.
General Information about your Nokia 1680 unlock code
When you receive your email with your unique Nokia 1680 unlocking codes, you may see there's actually more than one code.
Depending on your model you may receive two codes for newer phones or seven codes for older Nokia models
(Please see below for some examples)
If you receive a code without the #pw+ at the beginning or EG +1# at the end, then you need to add this to the code before you enter it.
For example, if you receive 418636523456123, then the code is actually #pw+418636523456123+1# (Should normally be +1# on the end).
PLEASE NOTE
WHEN ENTERING A CODE, be very carefull, Nokia models only allow 3 attempts to enter a code, after this they will lock themselves.
When you enter a code and it returns an error code, STOP and contact us, making a note of the error exact message. If you continue it will affect your chances of a refund.
However it is worth trying to use your new SIM as some phones can falsly report a 'Code Error'
How to enter your Nokia unlocking code
Use the * (Star) Key to get the p w and + characters.
Press * key 3 times for p
Press * key 4 times for w
Press * key 2 times for +
Please note: You only have 3 attempts to enter this unlocking code.
To start with, when you turn your phone on without a SIM card you should see the message 'RESTRICTED'. If you don't see this message, turn the phone off and insert a non-accepted SIM card (ie not locked to) and carry on as normal.
Nokia Cell... | Answered on Jul 22, 2020
not the way it works here!
Unlock Nokia 1200 Phone ' Unlock Code - UnlockBase
www.unlockbase.com > unlock-phone > nokia > 1200
How to Unlock Nokia 1200? 1 - Switch ON your phone without SIM Card, 2 - Compose #PW+CODE+1# (if locked from Fido ...
Codes NOKIA 1200, how to - HardReset.info
www.hardreset.info > devices > nokia > nokia-1200 > codes
Here you can find all secret codes for NOKIA 1200. ... Unlock service provider: Insert sim, turn phone on and press vol up-arrow keys) for 3 seconds, should say ...
Nokia Cell... | Answered on Jul 09, 2020
What unlocking code do you want?
Nokia Cell... | Answered on Jun 09, 2020
Nokia Inc 002L103 N97 Touch Screen phone Logo
15 questions posted
Popular Products
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
no unlock code
  • Cell Phones
