20 Most Recent LIVING ACCENTS Grill Gazebo Questions & Answers
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Garden | Answered Yesterday
Refer this question to Dixie Chopper. You might even to be able to get illustrated instructions.
Garden | Answered 2 days ago
First spray some starter fluid into the carb. If it starts you still have a fuel problem. If no spark then check the coil connections and the ignition box connections. Check for a spark at the plug. Check the engine compression. The backfire may have been caused by the a valve that was open when it should have been closed.
Garden | Answered 3 days ago
I don't think it matters though somehow storing it level seems more sensible.
It is more important to store it where it will be protected from wide extremes of temperature and high humidity that creates lots of condensation - this is due to the amounts of flexible materials in the motor and the ignition module.
Long term storage should be with an empty fuel tank and the engine run until the carb is empty.
Garden | Answered on Jul 31, 2020
never heard of the brand
Garden | Answered on Jul 30, 2020
I would go to Yesterdays tractor website. ( ytmag.com ) someone in the mower forum will know where you can get one or they will post a diagram for you.
remove the battery and let it dry out for a few days. you might get lucky and itll work again
Garden | Answered on Jul 29, 2020
Take off the mower casing and clean out all of the debris inside. Use blasts of compressed air, a vacuum, or a toothbrush to knock debris loose. If this doesn't fix the overheating problem, the next most common cause of the problem is a low oil level.
Garden | Answered on Jul 26, 2020
If the unit is brand new you should return it to the supplier as defective - damaged in transit.
If not new but is a quality unit it should be possible to obtain a spray head as a spare part from the supplier or manufacturer.
Garden | Answered on Jul 25, 2020
Contact Simplicity directly to request the diagram you need.
LIVING ACCENTS Grill Gazebo Logo
0 questions posted
Top LIVING ACCENTS Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a LIVING ACCENTS Garden Expert? Answer questions, earn points and help others
View Most Popular
  • LIVING ACCENTS Garden
Most Popular Question
adjust valve troy built riding mower
  • Garden
