20 Most Recent Acu-Rite Acurite Wireless Weather Thermometer 604 Questions & Answers
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Acu-Rite Acurite... • Answered on Oct 02, 2018
How do I change the clock from 24hr to 12 hr?
Acu-Rite Acurite... • Answered on Mar 16, 2017
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Acu-Rite Acurite... • Answered on Sep 22, 2015
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Acu-Rite Acurite... • Answered on Sep 11, 2015
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Acu-Rite Acurite... • Answered on Jul 20, 2015
Hi Jerry, While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Acu-Rite Acurite... • Answered on Nov 07, 2014
Hi Mona, To set the time on your 00604 thermometer. Press and Hold the Time button until the Hour begins flashing. Release Time Press and Release the + or - buttons to adjust Press and Release Time and the Minutes will flash Press and Release the + or - buttons to adjust Press and Release Time to lock in your setting.
Acu-Rite Acurite... • Answered on Sep 26, 2014
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
124 questions posted
Top Acu-Rite Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Acu-Rite Measuring Tools & Sensors
Most Popular Question
acurite wireless weather will not work
  • Measuring Tools & Sensors
