20 Most Recent
Honeywell TE852W Weather Forecaster With Wind Speed and Temperature Questions & Answers
The weather Forecast Icons don't change on my
Hi,This problem could arise due to various reasons1)Replace the batteries in remote sensorsWhen the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and holdDOWN on the main unit.2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.3)Reset the unit and checkpost a comment for further assistance.Thank you for using fixya have a nice day:-)
I have a Honeywell te657w
These type of displays are not ment to be seen in direct sunlight or with a lot of light directly on them.
The backlight in the unit is used for night viewing and i'm unaware of an adjustment for it. If you are looking for a unit that you can have exposed to direct sunlight then you need to get one designed for this that will have atleast 4000nits (brightness required to shine more than the sun).
5/25/2016 2:05:38 AM •
Honeywell...
Answered
on May 25, 2016
Hi, there is no provision as to brighting the display on your Honeywell Weather Station. What you are experiencing is faulty display that is gradually fading off and as time goes on it will be blank. So you should start planning on replacing the display....
11/20/2013 5:18:46 AM •
Honeywell...
Answered
on Nov 20, 2013
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
