20 Most Recent
Bose QuietComfort 2 Acoustic Noise Cancelling Headphones Questions & Answers
When I use the headphones listening to TV, I get
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
4/18/2011 10:54:01 AM •
Bose...
Answered
on Apr 18, 2011
How can I connect an SA-2 amplifier to the BOSE 321 Series II Media Center?
To connect an SA-2 amplifier to a BOSE 321 Series II Media Center, you will need to use a 3.5 mm audio cable. Connect one end of the cable to the headphone jack on the SA-2 amplifier and the other end to the auxiliary port on the BOSE 321 Series II Media Center. Once connected, you will be able to enjoy amplified sound from your media center.
How do you set up menue, Bose music wave?
Voici les ?tapes g?n?rales pour configurer ces appareils :
Pour configurer le menu Bose :
Veuillez Allumer votre appareil Bose.
Appuyez sur le bouton « Menu » pour acc?der au menu.
Utilisez les fl?ches directionnelles pour naviguer dans le menu.
Appuyez sur le bouton « OK » pour s?lectionner une option.
Suivez les instructions ? l'?cran pour configurer les diff?rents param?tres.
Pour configurer la vague musicale Bose :
Allumez votre vague musicale Bose.
Appuyez sur le bouton « Setup » pour acc?der au menu de configuration.
Appuyez sur le bouton « Setup » pour s?lectionner une option.
Suivez les instructions ? l'?cran pour configurer les diff?rents param?tres, tels que la connexion Wi-Fi, la synchronisation avec d'autres appareils, etc.
Bose lifstyle 48 lost connection to other rooms
If you are having trouble with your vehicle's 4-wheel drive, there are a few possible causes:
1. Electrical issues: One possibility is that there is an electrical problem with the 4-wheel drive system, such as a faulty transfer case shift motor, a broken wiring connection, or a malfunctioning switch. These issues can prevent the 4-wheel drive system from engaging properly.
2. Mechanical issues: Another possibility is that there is a mechanical problem with the 4-wheel drive system, such as a broken or worn transfer case chain, a damaged or malfunctioning front axle, or a worn-out clutch or gears in the transfer case. These issues can prevent the 4-wheel drive system from functioning properly or can cause it to engage or disengage unexpectedly.
To diagnose the issue, it is recommended to take your vehicle to a qualified mechanic or dealership for further inspection and diagnosis. They can perform a variety of tests and inspections to identify the root cause of the problem and recommend the appropriate repairs. Some common diagnostic tests may include checking for error codes with a diagnostic scanner, performing a visual inspection of the components, and testing the 4-wheel drive system under load.
Bose 901 equalizer connect to Lafayette 3500 receiver using bose 901 speakers
The Bose 901 speakers require the use of a specific equalizer that is designed to optimize their performance. If you have a Bose 901 equalizer, you will need to connect it to your Lafayette 3500 receiver in order to properly use the speakers.
Here are the general steps for connecting the Bose 901 equalizer to your Lafayette 3500 receiver:
- First, ensure that the power is turned off on both the receiver and the equalizer.
- Locate the preamp output jacks on your Lafayette 3500 receiver. These will typically be labeled as "pre out" or "line out".
- Connect a pair of RCA cables from the preamp output jacks on your receiver to the input jacks on your Bose 901 equalizer. These jacks are typically labeled as "preamp in" or "line in".
- Next, connect another pair of RCA cables from the output jacks on your Bose 901 equalizer to the main amplifier input jacks on your receiver. These jacks are typically labeled as "main in".
- Turn on your receiver and equalizer, and ensure that the volume levels are set to a low level before playing any music.
- Set the Bose 901 equalizer to the "On" position, and adjust the various equalizer controls to your preferred settings.
- Finally, play some music and adjust the volume levels as needed. You should notice a significant improvement in the sound quality of your Bose 901 speakers with the equalizer properly connected.
Note: It's important to use the Bose 901 equalizer specifically designed for the speakers. Using a different equalizer or not using any equalizer at all may result in poor sound quality or damage to the speakers.
Bose wave radio sound only works when alarm goes off
It sounds like you are experiencing an issue with your Bose Wave radio. Here are a few things you can try to troubleshoot the problem:
- Make sure the volume is turned up on both the radio and any external devices (such as a phone or MP3 player) that may be connected to the radio.
- Check to see if the radio is in "alarm" mode. If it is, try switching it to "radio" mode and see if you can hear sound.
- Make sure the radio is properly connected to a power source and that the power cord is securely plugged in.
- If you are using an external device (such as a phone or MP3 player) to play music through the radio, make sure the device is properly connected to the radio using the appropriate cable.
- If none of these troubleshooting steps resolve the issue, the problem may be with the radio itself. In this case, you may want to contact Bose customer support for further assistance.
Bose remote rcv1t-27 not working
If it's still not working, contact Bose, sometimes they will ship a replacement at no charge, if not, ship it and $20.00 to me and I will repair it or get you a replacement, if for some unseen reason it is un repairable or I am unable to get a replacement, you will get a full refund, see my feedbacks on Letgo in Fairfield California under Supertech99, 100% 5 Star feedback and reviews, I am the real deal.
