20 Most Recent
Clarion APA4320 Car Audio Amplifier Questions & Answers
Clarion apa4320 amp power light pulses
There is not enough power coming from you radio to power the amp. You might want to look in to a capacitor. What this will do is it will pull in the power and maintain a steady output for your amp to operate
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
The current draw of amp (apa4400g) burning car
You can either change out the altinator to one that puts out more amperage, or , Like me, have the old altinator "beefed up" to put out more amps. It is an easy fix on some altinators. They just replace the insides, or, rewind the one you have. Look for a altinator repair/ battery shop. They have several where I live.
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
DOES CLARION BD357MP HAVE BLUETOOHT INTEGRATED
No, the Clarion BD357MP car stereo receiver does not have Bluetooth integrated. The receiver was released in 2007, and Bluetooth integration in car stereo systems was not as common at that time as it is now.
However, you may be able to use a Bluetooth adapter to connect your phone or other Bluetooth-enabled device to the stereo. Some aftermarket Bluetooth adapters can be plugged into the auxiliary input of the stereo or connected via an FM transmitter to add Bluetooth functionality. Check the compatibility of any adapter with your Clarion BD357MP receiver before purchasing to ensure it will work properly.
Clarion db185 mp no sound
If your Clarion DB185 MP head unit is not producing any sound, here are some steps you can try to troubleshoot the issue:
- Check the wiring: Make sure that all the wiring is properly connected and there are no loose connections. Check if the speaker wires are connected to the correct terminals on the head unit and the speakers.
- Check the fuses: Make sure that the fuses are not blown. Check the fuse box in your car and make sure that the fuse for the head unit is intact.
- Check the volume: Make sure that the volume is turned up and not muted. Check if the "MUTE" function is activated.
- Check the balance and fade settings: Make sure that the balance and fade settings are set correctly. If the sound is only coming from one speaker, it could be because the balance is off.
- Check the sound settings: Make sure that the sound settings are not set to "FLAT" or "OFF". Adjust the equalizer settings to see if it improves the sound.
If none of these steps work, then the problem could be with the head unit itself. You may need to take it to a professional to have it checked and repaired.
