20 Most Recent Suzuki Service Manual, 2 - 65 HP Outboards & Jet Drives, 1992-1999 Questions & Answers
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Suzuki Service... | Answered on Jun 24, 2014
Did you lose it or can it be repaired?
Suzuki Boating | Answered on Jul 11, 2019
50:1 ratio for the Suzuki outboard motor
Suzuki Boating | Answered on Jun 16, 2019
To be safe get a marine mechanic to go over it to be safe.
In general they are a good motor.
Good luck.
https://www.youtube.com/watch?v=8qDlYPVkrTA
Suzuki Boating | Answered on May 30, 2019
if you are happy with current propeller then take prop off lower unit and look on the backside of the prop..it should show size and pitch close to center
Suzuki Boating | Answered on Mar 04, 2019
Turn the carburetor upside down. The float should be level with the bottom of the carburetor.
Suzuki Boating | Answered on Feb 19, 2019
K. All outboards from the 1980's out have a built in kill switch. The most common problem for your issue is the shifter cable ( the one that puts you into forward ,neutral, or reverse) is stretched and you are not quite in neutral and are tripping the built in kill switch. Depending on the engine you will either not have anything happening when you turn the key or you will have zero spark or both. It is there to keep you from flying off the boat if you leave it in gear and forget. ... the second is corroded ground or loose ground on the engine or the battery. And third is a blown fuse at the engine end. To check if the problem is your shifter cable , just detach it from the engine and manually place it in neutral by grabbing the shift leaver located on the motor then try starting it again. If thats the issue then adjust the cable and order a new one and have it on stand by.. Throttle cable also. Both usually need to be replaced at the same time.
Suzuki Boating | Answered on Dec 20, 2018
you need to get a manual for that model
I suspect that the hose to the unit on the block is the tank hose to the fuel pump and there should be a hose from that unit ( fuel pump ) to the carby
the hose from the crankcase is possibly the hose that works from the pulses of the piston ( suction/ pressure ) that works the pump diaphragm to pump the fuel
If you are getting fuel into the sump I would suspect a hole in that diaphragm
discuss the problem with a service center for that make
Suzuki Boating | Answered on Jun 10, 2018
posts are not linked so every post has to include all of the details
in the time it took for me to answer this there were 20 extra posts added
Suzuki Service Manual, 2 - 65 HP Outboards & Jet Drives, 1992-1999 Logo
5 questions posted
Top Suzuki Boating Experts
Marvin
Marvin
jws1013
Andrew Taylor
Andrew Taylor
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
View Most Popular
Suzuki Boating
  • Suzuki Boating
Most Popular Question
65hp suzuki outboard motor wont start
  • Boating
