20 Most Recent Clarion VRX745VD Car DVD Player Questions & Answers
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Clarion VRX745VD... • Answered on May 09, 2017
This particular head unit has a built in amplifier for the cars speakers. Unfortunately it does not have preamp RCA outputs which means to use an external Line out convertor. These are easy to find on crutchfield.com, any local car audio shop, or best buy. Once you receive your LOC it will have instructions telling you how to connect it. Generally you will tap it into the speakers High and Low wires, a remote wire (ignition signal), and a ground connection. The RCAs will be supplied out of the back of this device ready to be hooked up to your amplifier.
Clarion VRX745VD... • Answered on Apr 30, 2011
Screw it to a piece of metal on the car inside or out use self tapping screw
Clarion VRX745VD... • Answered on Mar 30, 2011
6200 Gateway Drive, Cypress, CA 90630, U.S.A.
Customer Service: 800-347-8667
Phone: 800-GO-CLARION (462-5274)
Fax: 310-327-1999
Clarion VRX745VD... • Answered on Jan 29, 2011
try pacparts.com.
Clarion VRX745VD... • Answered on Jan 14, 2011
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
and the audio only should be that your handbrake is not up or check the grass green wire connect it to ground and this will allow you too watch dvd's whilst u drive
pls rate
Clarion VRX745VD... • Answered on Aug 19, 2010
if the sterio is not originnally from the vehicle and is factory fitted sometimes instead of a code it can make the dreaded beep. The originalvehicle is syncronised with the head unit and the only way to get it to work in another vehicle is to have it syncronised with the new vehicle. Some garages can do this but charge around £20. Its an anti theft system. Hopr this helps :)
Clarion VRX745VD... • Answered on Jun 26, 2010
If you go to any Car Audio shop, you can get the installation kit, wire harness, and antenna adapter. 90% of the installation can be done at the kitchen table, then pull the factory radio and the new unit will plug into the factory harness and bolt into the factory locations. Make sure you have the vehicle with you when you get the parts so they can look at the factory radio and make sure you get the right parts. If it a factory Bose system, let a professional do it, there is rewiring that will have to be done. Hope this helps
Clarion VRX745VD... • Answered on Jun 18, 2010
ebay electronics
Clarion VRX745VD... • Answered on Jun 15, 2010
u have blowed channels on ur flipout
Clarion VRX745VD... • Answered on Feb 08, 2010
Have you checked out Ebay.
They sell lots of car radio bits
Clarion VRX745VD... • Answered on Oct 15, 2009
Go to www.clarion.com click united states...then type vrx745vd and look to your right...you can download..
with the face plate out...look to the right and use a pencil or pen.
Find this item in ebay...type vrx745vd and you will find it.
the brown wire is more than likely a telephone mute wire. it is used to mute the audio when answering a phone in your vehicle.
Clarion VRX745VD... • Answered on Aug 19, 2009
Clarion VRX745VD Car DVD Player Logo
35 questions posted
Top Clarion Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Clarion Car Audio & Video
Most Popular Question
need face plate vrx745vd
  • Car Audio & Video
