20 Most Recent Clarion VRX755VD Car DVD Player Questions & Answers
Try this: Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Clarion VRX755VD... | Answered on Feb 10, 2018
The parking brake (usually light green) wire from the stereo needs to rest at ground to view videos.
Clarion VRX755VD... | Answered on Jul 26, 2012
You will need one pair of RCAs connected to the unit in the rear where it says "sub" and a remote turn (connected to the radios blue and white wire) on running from the radio(with the RCAs) to an amplifier. You will also need a power cable from the battery and a chassis ground coonected to the amp. Connect the subs (usually in some sort of enclosure) to the amp.
Their is a reset button under the detachable face plate it might help. Its the flashing light it should reset the unit
Clarion VRX755VD... | Answered on Jun 13, 2012
Well, it sounds like you need a new output IC, which is what produces sound to the speakers.
Clarion VRX755VD... | Answered on Apr 03, 2012
i have the same model its the green wire next to the earth wire bottom row make sure u earth it otherwise the unit can be frustrating at times!!!!
Clarion VRX755VD... | Answered on Jun 24, 2011
Try to turn off the radio first and then turn it back on then press the eject button repeatedly. If it still not working then the problem is with the radio itself. Give it back to the dealer where you purchased it, im sure that its still covered with the warranty since its brand new.
Have a blessed weekend.
Clarion VRX755VD... | Answered on Apr 24, 2011
Hola.
Chequea el cable de alimentacion. Utiliza un Voltiometro para controlar si hay voltage. Si no hay corriente en el cable de alimentacion puedes necesitar cambiar el fusible de 15 amp incluido en el cable.
Clarion VRX755VD... | Answered on Feb 11, 2011
Disconnect all speakers and hook up one test speaker. If that works hook each speaker up one at a time and test each one.
Clarion VRX755VD... | Answered on Feb 04, 2011
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Clarion VRX755VD... | Answered on Sep 25, 2010
check the parking wire of the dvd player
Clarion VRX755VD... | Answered on Aug 26, 2010
that is where its suppose to be connected it that you dont have it grounded properly
Clarion VRX755VD... | Answered on Aug 19, 2010
Clarion VRX755VD Car DVD Player Logo
47 questions posted
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Clarion Car Audio & Video
Most Popular Question
no sound clarion
  • Car Audio & Video
