20 Most Recent Lock Cylinders Questions & Answers
Removal & Installation
Before servicing any vehicle, please be sure to read the precautions section, which deals with personal safety, prevention of component damage, and important points to take into consideration when servicing a motor vehicle.
WARNING Vehicle must be in PARK prior to ignition cylinder removal.
  1. Disconnect the negative battery cable.
  2. Disable the SIR (air bag) system, as outlined in the Chassis Electrical Section.
  3. Remove the steering column trim covers.
  4. Insert key into the ignition and rotate to the RUN position. Then rotate ignition cylinder back to ACC position.
  5. Depress the locking button through hole on side of ignition module assembly with a thin pick-type tool then slide the lock cylinder from the ignition housing.
    Fig. Depress the locking button through hole on side of ignition module assembly
To install:
NOTE If you are installing a new lock cylinder, recoding will be required and a J 41340, Lock Cylinder Holding Fixture and Staking Tool will be required.
NOTE Ignition lock cylinder reads key cut position 1 through 9.
  1. Insert the appropriate tumbler (3) according to the key code into the corresponding tumbler ward.
    Fig. Ignition lock cylinder reads key cut position 1 through 9
    Fig. Insert the appropriate tumbler according to the key code into the corresponding tumbler ward
  2. The tumblers will not immediately seat into position because the sidebar has been pre-assembled. The tumblers will have to be pushed past the sidebar with a small flat screwdriver or pocket knife.
  3. The tumbler springs (2) should then be inserted into the spring wells in the cylinder (4) where they will sit on top of the tumblers.
  4. The seal plate (1) will be installed and crimped.
  5. Insert the seal plate locator legs into the receptacle slots in the cylinder--seal plate will seat into position only when the two locator legs have been properly inserted into the receptacles on the cylinder.
  6. While holding the seal plate in position with the thumb, insert the key into the cylinder and watch for the side bar to drop. If the side bar does not drop, the lock is tumbled wrong and you need to start over.
  7. Ensure that the side bar does not drop on an angle. The side bar must be completely flush to the cylinder diameter.
  8. Stake (1) the two metal areas of the cylinder (2) directly over the seal plate legs with a hammer and punch or chisel.
    Fig. Stake (1) the two metal areas of the cylinder (2) directly over the seal plate legs with a hammer and punch or chisel.
  9. Repeat this stake on the areas of the cylinder directly opposite of the first to stakes.
    NOTE Actuator blade within the ignition module must be in ACC position to install the lock cylinder assembly. If rotated, reposition the actuator blade to the ACC position using needle nose pliers.
  10. Insert key into ignition lock cylinder and install the cylinder into the lock housing.
  11. Rotate the lock cylinder in the housing. Verify proper rotation.
  12. Install the steering column trim covers.
  13. Enable the SIR system.
  14. Connect the negative battery cable.
Lock Cylinders | Answered on Oct 12, 2010
do you have to add coolant and is there a rear heater core in rear ??
Thule Vehicle... | Answered on Feb 09, 2015
Are the bolts seized or is there a release pin?
Thule Vehicle... | Answered on Sep 02, 2014
Are these factory acessories or another name brand?
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
Thule Vehicle... | Answered on Jan 01, 2014
Demi,
The Loadcarrier 1061 is an older model and onl;ine data is hard to find, if there at all. To know more about the feet and fit kit, I recommend you call Thule Customer Support line at 800-238-2388 (Monday - Friday 8:30AM - 5:30PM EST).
Hope this helps. - RedRanger
Thule Vehicle... | Answered on Nov 16, 2013
Repost under RV for an answer
Thule Vehicle... | Answered on Jul 25, 2013
Will any metal detector manual serve, or do you have a specific make and model in mind?
Vehicle Parts &... | Answered on Sep 15, 2020
I had a problem similar to that which you described the car would start fine then few seconds later it would cut out completely.
i changed the fuel pump, Fuel pump relay and still the problem was there and a a code of P0230 i cleaned the ECU connections which still didnt change anything so i put a jumper wire to bypass the fuel pump relay it got it to work fine.
With abit more digging and head scratching i opened up the ECU and found one wire broken.
I soldered it back in place and behold the car worked a dream no problem ever since.
I also removed the bypass which i put on the fuel pump relay and put the relay back.
Dont know if this would fix your problem but hopefully it would be of help.
Vehicle Parts &... | Answered on Jul 10, 2020
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc.
A nice Auto folie will enhance the appearance of your vehicle.
Vehicle Parts &... | Answered on Jun 09, 2020
you can purchase from:
https://www.amazon.com/Adapter-Charger
Vehicle Parts &... | Answered on May 29, 2020
https://help.compustar.com/s/article/How-Do-I-Exit-and-or-Enter-Valet-Mode
You can see this link.
Vehicle Parts &... | Answered on May 07, 2020
Suggest to do a patent search and review some diagrams. That will get you started.
Vehicle Parts &... | Answered on Feb 13, 2020
Google
year make model valet button
it is impossible for us to guess!
Vehicle Parts &... | Answered on Jan 12, 2020
on a car security, no idea, but on Android, this is how.
How to reset your Android screen lock security pattern ... TechRepublic Draw the pattern, click Continue, draw the pattern again, and you're back in business. You can also increase the security of your phone by setting it to lock ...
How to reset your Android screen lock security pattern TechRepublic
Vehicle Parts &... | Answered on Jan 06, 2020
Lock Cylinders Logo
3 questions posted
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Marvin
Marvin
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Thule Vehicle Parts & Accessories
Most Popular Question
changing out ignition lock cylinder 04
  • Vehicle Parts & Accessories
