20 Most Recent Microsoft Windows XP Professional Edition With Service Pack 2 for PC Questions & Answers
This error in kundli 2009 is because of missing hidxp.dll
Below are the links to fix this error
hidxp dll error fix How can fix hidxp dll error effectively
or
What HIDXP DLL Best How to Fix HIDXP DLL Error Guide
Thank You!
Microsoft... | Answered on Jan 25, 2016
D3JMD-XDV9V-DCKBQ-PKF4C-X3TJT
Microsoft... | Answered on Aug 26, 2015
You need to use Windows XP Professional SP3 media dvd if you want to use your XP Pro SP3 product key. As far as I know, the SP3 product key does not work with the previous version of media (non-SP, SP1, and SP2).
Microsoft... | Answered on May 07, 2014
If you have a desktop computer, look for the "genuine" Microsoft decal on the side/back of the case.
If you have a laptop computer, look for the "genuine" Microsoft decal on the bottom of the case.
You'll find a 25-character license-key. Enter that key, when prompted, during the installation of Windows XP.
Microsoft... | Answered on Mar 31, 2014
Test your software and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Microsoft... | Answered on Mar 04, 2014
The link below will take you to Microsoft's website which will allow you to download service pack 3. Remind you that this is the full install for service pack 3 and will require service pack 2 already installed.
http://www.microsoft.com/en-us/download/details.aspx?id=24
Microsoft... | Answered on Dec 17, 2012
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Microsoft... | Answered on Aug 17, 2012
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Microsoft... | Answered on Jun 22, 2012
Upgrade to Service Pack 3, ie8 will work better and should solve the lag time between audio and video.
Microsoft... | Answered on Jun 18, 2012
try to open your windows in safe mode. (when you turn on your PC press F8 repeatedly), then choose safe mode. Once you entered on safe mode, go to start, RUN then MSCONFIG. then go to STARTUP. Uncheck all items then OK restart.
Microsoft... | Answered on May 10, 2012
QW4HD-DQCRG-HM64M-6GJRK-8K83T THIS PRODUCT KEY WILL HELP YOU
Microsoft... | Answered on Aug 29, 2011
There are a couple of solutions to this problem but most of them require technical use of drive partition tools like Bart Pe or partician magic or some linux tools can move NTF files around as well.
.The simplest way is to back up your data and reinstall windows making sure that you delete and reformat all partitions when doing the install.
I hope this helps
Andrew
Microsoft... | Answered on Mar 26, 2011
Welcome to Fixya. The problem with the connection is that you need to check if the Windows XP SP2 settings is the same with the router.
First you need to access the router settings page and check if the security is the same of the computer. Access the router type 192.168.1.1 then type admin for username and password for password. Select Wireless Settings. I need to verify if the Dot is on WPA2-PSK (AES).
If the settings is the same as above then we will configure the settings on your Windows XP Laptop.
- Go to Control Panel, Network Connection, Right Click on Wireless Network Connections then select Properties.
- Click on the Wireless Networks Tab on the Wireless Network Connection Properties window.
- Hightlight the SSID or Your Network Name and the click on the Properties Button.
- If your using WPA2 then change the dropdown to WPA2-PSK if the option is available.
- Data Encryption is AES same with the router, then retype the Network Key that you save on the router
- Then click Ok to close the window. Try to browse and hopefully this fix the issue.
If you have questions please let me know. Thanks for using Fixya.
Microsoft... | Answered on Mar 06, 2011
Try this here: KYKVX-86GQG-2MDY9-F6J9M-K42BQ
Microsoft... | Answered on Jul 15, 2010
Yes, it sounds like a computer-virus.
Remove the disk-drive from your desktop computer,
and attach it as a "slave" disk-drive to some other desktop computer, and then run a full virus-scan.
Or, just follow "best practises":
* backup your data & music & E-mail & contacts,
* reinstall Windows from trusted media,
* run Windows Update a bunch of times,
* reinstall anti-virus software,
e.g., http://www.microsoft.com/security_essentials
* reload your files.
Microsoft... | Answered on Apr 18, 2010
i need to download hp laserjet 1010 driver for windows xp
Microsoft... | Answered on Dec 28, 2009
there is no product key for these discs, they are system restore discs and you have to use your windows licence key that is on a sticker on the pc. if you do not have a licence key sticker you will have to purchase one from Microsoft.
Microsoft... | Answered on Nov 27, 2009
Microsoft Windows XP Professional Edition With Service Pack 2 for PC Logo
Popular Tags
32 questions posted
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
windows xp service pack 3 serial key
  • Computers & Internet
