20 Most Recent
Clarion DB-235 CD Player Questions & Answers
I need schematics for wiring ,colors etc..
Red 12 volt switched
yellow 12 volt constant
black ground
white left front +
white/black left front -
gray right front +
gray/black right front -
green left rear +
green/black left rear -
purple right rear +
purple/black right rear -
if you need more information or there are more wires please feel free to send me a message. Please rate.
How to set clock
If you run it by an Automotive Audio Installer shop, they usually know- that's the easiest way, unless you have the directions. I couldn't find a manual on the net, but hope this helps.
Which wire on the back of the radio is aux in? I
Your receiver does not have an AUX input, so you will need an adapter. Should be easy enough to find, there are many to choose from. Just go to any electronics store. What wires you'll need to connect will depend on what type of AUX accessory you buy. It could plug into the lighter, it may need to be wired.
You could also use an FM modulator. They work well enough in my experience(I'd stay away from Belkin though). This would probably be the cheapest solution and you would still use the AUX inputs and would not have to install/uninstall anything, just plug and play and run your antenna. You may want to wire the power to the 12v power wire on the back of your stereo if the FM modulator needs to be plugged into the lighter, if not then don't bother and just use the lighter to power the satellite radio receiver. :-)
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
DOES CLARION BD357MP HAVE BLUETOOHT INTEGRATED
No, the Clarion BD357MP car stereo receiver does not have Bluetooth integrated. The receiver was released in 2007, and Bluetooth integration in car stereo systems was not as common at that time as it is now.
However, you may be able to use a Bluetooth adapter to connect your phone or other Bluetooth-enabled device to the stereo. Some aftermarket Bluetooth adapters can be plugged into the auxiliary input of the stereo or connected via an FM transmitter to add Bluetooth functionality. Check the compatibility of any adapter with your Clarion BD357MP receiver before purchasing to ensure it will work properly.
