20 Most Recent
Targus 4PORT USB 20 TRAVEL HUB ACH7405US ACH7405US Questions & Answers
So I purchased a Targus
You can download the driver from the Targus website.
Here is an alternate link
https://www.solvusoft.com/en/update/drivers/usb-hub/targus/models/
I plug in the 4
sometimes you have to plug a usb into these to get them to respond if this does not work try plugging it into another USB port. If this does not work than look at the wires they may have come unattached
Will not power my usb
Small travel hubs use power from the Notebook's USB port, the issue you are experiencing is "most likely" caused by there not being sufficient power output to allow all devices to run successfully - the following devices should be connected directly to the notebook:
* External hard drives
* Printers
If the issue occurs with Mouse, USB Key / Dongle Drives, Keyboard then the issue is either a faulty peripheral ( the mouse/ Key etc) of with the Dongle itself.
Can this be used with my home computer to rum my
This is a straight forward USB hub, allowing you to expand a sing USB port to four
USB ports. anything you normally connect to a USB port on your PC can be connected through this. The only thing to remember is that the USB port on the PC is designed to provide 500mA of current, and if you use a USB hub then the total current of all devices connected is still 500mA. If you require more power then you can buy powered USB hubs.
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
- Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
- Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
- Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
- Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
- Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
