20 Most Recent
LaCie 130894KUA Core7 USB 20 Hub Questions & Answers
I connected my HP Color
USB Hubs are generally a bad idea for big USB devices
for big devices like printers and scanners it is generally rule of thumb to connect them directly to the USB port as USB Hubs share the voltage over many ports and data can be lost if multiple peripherals are using the one port
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
