20 Most Recent Konica Minolta Dynax 5D / Maxxum 5D Digital Camera Questions & Answers
You're not trying to connect a high speed USB device into a low speed bus, are you?
Konica Minolta... | Answered on Jan 14, 2018
two reasons for this are possible:
1) you changed the exposure compensation by mistake to minus something... - see below - change it again to +- zero:
Konica Minolta MAXXUM 5D Instruction Manual Exposure Compensation
2) you should have the ISO settings to auto:
Konica Minolta MAXXUM 5D Instruction Manual Camera Sensitivity iso And...
Konica Minolta... | Answered on Mar 02, 2015
was it working before?
turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
Or try another card to exclude yours is not damaged or wrong type somehow....
Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
Konica Minolta... | Answered on Mar 07, 2014
I'm curious, did you know:
Please be informed upon the termination of the Agreement between Sony Corporation and Konica Minolta Photo Imaging, Inc.. Konica Minolta will cease the entire customer services for Konica Minolta cameras and related products, as of 31 December, 2010.
After 1 January, 2011, the Repair Service Providers will continue support for the repair service independently.
here is a link to this: http://ca.konicaminolta.com/support/repair/index.html
On another note, and to try to help gain a solution to your problem...
My camera (the Nikon Coolpix L110) uses special batteries made by Nikon and they are very adamant on not using other battery brands... in fact, using other brands may negate their warranty. Is it possible yours also requires a special battery?
I ask because I'm having the same problems with my camera and just learned of the special Coolpix batteries. I guess I should have read the instructions more thoroughly,.. but I don't recall seeing this before tonight while I was looking for a solution to my own problem; blurry pictures as well.
I'm going to try the Coolpix batteries to see if this helps. Perhaps you might do the same if you find yours also uses a special battery. Good luck!
Konica Minolta... | Answered on Aug 06, 2013
Try downloading the photos to a computer. If this doesn't work there may be a problem with the flash chip. If so, try reformatting it - that worked for me when I had a couple of photo storage locations that constantly put up garbage displays and produced file error messages on downloading.
Konica Minolta... | Answered on Jul 20, 2013
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Konica Minolta... | Answered on Aug 02, 2012
inside of the camera are some parts, that can be broken or loose see the diagram, and proceed with common sense. God bless you
Konica Minolta... | Answered on Jul 22, 2012
Konica Minolta Dynax 5D / Maxxum 5D Digital Camera Logo
47 questions posted
Top Konica Minolta Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Cameras
Most Popular Question
battery charging
  • Cameras
