20 Most Recent
Konica Minolta DiMAGE F300 Digital Camera Questions & Answers
Minolta F300 battery cover Broken
Just do a Google search. There are a few hundred places to get the battery doors. They cost anywhere between $8 to $25, plus a few dollars for shipping.
Minolta digital camera F100
could be that the pad the button is supposed to press is not alligned with the button. it would take opening the camera, and thats already something that you shouldn't do if you're not comfortable with it.
I suggest you call minolta, and see how much they want for looking at it. that might already be a sum that will get you frustrated enough to open it up yourself, but it's worth a try.
Good luck
Ripples in the edges
It's an inevitable consequence of using a low resolution jpeg. Try setting your computer monitor to VGA resolution (640x480) and you'll make a similar mess of images it displays - only worse, because the large screen blows up the image. You should use a higher resolution setting and invest in a bigger memory card for the camera if need be.
How do I clear pictures off the memory card?
The best way to remove all pictures from the memory card is to format it. This wipes all data from the card and prepares it for further use.Without knowing the model of your K-M camera I can't give you the exact procedure for formatting the card, but there should be a command somewhere in the menu system, probably under "Setup".
Konica Minolta Dimage Z6 working fine, but Windows 11 wont recognise it. Any ideas please?
If your Konica Minolta Dimage Z6 camera is working fine but is not being recognized by Windows 11, there are a few things you can try to troubleshoot the issue:
- Check the USB cable: Make sure that the USB cable you are using is properly connected to both the camera and the computer. Try using a different USB cable to see if that resolves the issue.
- Check the USB port: Try connecting the camera to a different USB port on your computer to see if the port is the issue. Some USB ports may not have enough power to detect the camera.
- Install the camera driver: If the camera did not come with a driver disc, try downloading and installing the driver from the manufacturer's website. Make sure to download the correct driver for your camera model and operating system.
- Restart the computer: Sometimes, restarting the computer can help to resolve issues with USB devices not being recognized.
- Try a different computer: If the above steps do not work, try connecting the camera to a different computer to see if the issue is with the camera or the computer.
If none of these steps resolve the issue, it is possible that there may be a hardware problem with the camera. In that case, it may be necessary to contact the manufacturer or a qualified technician for further assistance.
