20 Most Recent
Konica Minolta DiMAGE Z2 Digital Camera Questions & Answers
Unable to user carde
What type and size of memory card are you trying to use? The Z2 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
When using the flash no
Sounds like a short in the flash circuit. The repair won't be cheap. Get an estimate and decide if it's worth the expense.
Hi. I have a Dimage Z2 and I lost the front part
I have a very similar problem: The part is scratched at my camera.
I called the people here: http://support.sony-europe.com/DIME/KM/km.aspx?l=en
and was told that the parts are not available new, but they send me a good one from a used camera. The name is "front lense".
So good luck!
Whenever I put batteries in the camera it won't
The manual indicates that the camera should be able to use either alkaline or rechargeable AA size batteries.
Make sure that you are observing proper polarity of the battery as they are installed. Also double check the battery door. There should be 2 small metal strips that make contact with the batteries as well.
If polarity is being observed (see manual to double check), and the metal strips are both present, then it is likely that one of the contacts on the battery door or inside the camera are corroded, or perhaps broken. In either case, contact Minolta for repair assistance, or battery door replacement.
Broken battery door. I
Hi there, Turn down the camera & you find the battery door. After that watch the place, there is micro (+)screw present. Use a thin head small size screw driver for remove that. Be careful you must do it slowly. After remove the screw the door will remove from the body & then replace the door by using same process. I confirm you there is no cable connection. so, don't worry when you remove it.
Thanks & waiting for your feedback.
I need a service manual for the Dimage z2 Digital camera
Right, this is the info that you need. To remove and replace the battery door you need to follow 15 steps in the correct order, they are:
Remove the two screws (above lens) that hold on the flash cover.
Remove the flash cover
Remove the three screws on the view finder cover
Remove the view finder cover
Remove the two screws on the side of the battery compartment
Remove the two screws in the middle of the base of the camera
Remove the sliding cover on the left hand side of the lens
Remove the single screw on the left hand (curved) part of the camera case
Remove the single screw on the bottom left hand side of the casing
Remove the trim piece on the right of the camera next to the lens, the top has a sticky pad under it so will be difficult to lift up.
Remove the screw behind the trim plate
Remove the back casing
The flap should now be replaceable, if you do not feel comfortable with this then get a professional shop to do it.
Konica Minolta Z2 SDHC reading card
Spare yourself the trouble. I had researched it (I thought) and got one, and stuck it in. The screen read: "Unable to use," It continued to read this, even after I formatted the card, so I ended up giving it to my brother, who has a Kodak camera. Sorry!
My konica minolta Dimage z2 doesn't focus
Your problem may be that the camera is "locked" on manual focus. If so, you will need to go to the menu, scroll to "2" menu in "P" mode, and click on "focusing mode". From there, hit "single focus or continuous focus." It should correct the problem. Also, is the lens dirty? A dirty lens will not benefit the camera. The light may be too low, also. Try using a flashlight to focus, then take the picture.
