20 Most Recent
Breezaire WK1060 Wine Cellar Cooling Unit With Digital Temperature Display Questions & Answers
Breezaire WKCE 1060 unit in
HI.There might be some possibilities when it emits noise.First if the bossing of the fan from the shafting connecting the motor is already lossen,so when the fan starts to rotate it will make noise it will no longer as fit as the original one.Though it is not advisable to ke the unit open while its working,you can check how the motor works whenhileth unit is open for you to observe further
WK3000-7 yrs old. Stays on
Hi!!
Check your temp. settings and that the fan in the freezer/refrigerator is working, if items are working, (normal settings are about 1/2 way of the dial range). then your problem is a Refrigerant leak. When refrigerant level is low, the lines start to freeze but as soon as the compressor stops, the ice will melt. When there is a problem with the.defrost timer or the defrost coil, Ice builds up and takes up to a day with the fridge open to melt.
The repair of a leak in the system should be performed by a qualified HVAC Technician.
I suggest to call and ask how much would it be to repair the leak, then you decide if it is worth fixing or just replace it.
Good Day!!
9/26/2010 8:59:34 PM •
Breezaire...
Answered
on Sep 26, 2010
Have a Breezaire Sentinel II
If you wish for a Local Repair, tell me the Zip Code and i would try to Search for a Serviceman from our Listings.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/19/2010 4:02:32 PM •
Breezaire...
Answered
on Jan 19, 2010
Breezaire wkce 1060 does not cool my wine cabinet
I'm not familiar with your unit, but sounds like condenser problems. Check for a dirty coil on the backside or underneath the unit. Also, if it has a fan for that coil, make sure it's running when the compressor is running and that the blades are clean. Other than that, it could have developed a refrigerant leak.
9/15/2009 2:31:03 AM •
Breezaire...
Answered
on Sep 15, 2009
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
