20 Most Recent Whirlpool Refrigerator Icemaker Ice Maker Water Valve 4318047 Questions & Answers
water not filling icemaker faulty you may need technican.
Whirlpool... | Answered on Jan 17, 2016
To clarify, it won't stop making ice? If so,try the following:
Remove the ice maker.
Remove the wire bail.
Remove the front pop off panel, then the panel with the gear on front by removing 3 screws.
Look at the cam that the wire bail goes into. It should have a plastic pin that fits in the switch under it.
Mine had sheared off, so I driled a very small hole where the pin was, and put a finishing nail there. Cut to size. Mine works fine now.
Whirlpool... | Answered on Apr 27, 2015
you need to read the annual
Whirlpool... | Answered on Jan 21, 2015
Remove power from refrigerator remove 2 screws just above ice molds and some times on near front bottom then unplug wire from ice maker
Whirlpool... | Answered on Sep 12, 2014
What is the refrigerator model number? Sea Breeze
Whirlpool... | Answered on Jul 25, 2013
what is your model number is then we can get started then
Whirlpool... | Answered on Jan 22, 2013
Check your settings and make sure they are setting between 5 or 6.For More information please visit Ice Machine Cleaner .
Whirlpool... | Answered on Oct 17, 2012
In this order, check
The wire strainer where the water enters the appliance.
When was the filter changed?
Has it ever been descaled?
It might be the pump, partially blocked or failing.
Whirlpool... | Answered on Nov 12, 2020
CALL A REPAIR SERVICE LOCALLY IT AIR DAMPER MOTOR HAS A PROBLEM AND SOMETIMES EVER THE REPAIR PEOPLECAN NOT FIX
Whirlpool... | Answered on Nov 06, 2020
Release the latch that holds the lever up.
Whirlpool... | Answered on Oct 29, 2020
The manual for the UW8F2CXLSB gives the normal defrost procedure. Remove food (you can set the freezer to a lower temperature or the Fast Freeze setting to super chill the food first for several hours). Store the food in a cool location. Then remove the freezer drawers and turn off the unit. Leave the freezer door open and put some towels or other absorbent cloth in the bottom to soak up the ice water. Replace the wet towels with dry ones as needed. Once defrosted, clean and dry the freezer before turning it back on. Then return the food to the freezer. There isn't a fast defrost that I know of for this Whirlpool freezer.
I hope this helps.
Whirlpool... | Answered on Oct 17, 2020
Your drain is stopped up. The water is freezing because it has no where to go. Clear the drain line with compressed air.
Whirlpool Refrigerator Icemaker Ice Maker Water Valve 4318047 Logo
15 questions posted
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
new basic whirlpool refrig in freezer
  • Refrigerators
