20 Most Recent Amerock Double Magnetic Catch - White AM-M07-03941-664 Questions & Answers
I know Restoration hardware has super strong magnets so other places must have them as well. Drill a like sized hole in the door and the frame, Gorilla glue the magnets in the magnets, and there you go. This is a guess, but why wouldn't it work? Super glue might be better. Try it!
Amerock Double... | Answered on May 24, 2014
Most of the time all you need to do is swap the two handles and flip the latch over so the angled part of the latch is on the other side, so it will self latch when you close the door.
Amerock Hardware... | Answered on Jun 15, 2018
Have you tried calling AmerlockForLess.com for assistance? On their website they say: "American customer service reps by phone from 8:30 to 5:00 M-F. Our toll free number is 1-877-261-5805."
Amerock Hardware... | Answered on Apr 07, 2018
Look for a small hole or slot on or around the handle, Push a pin inside to unlock it.
Amerock Hardware... | Answered on Feb 12, 2015
If you can take the lock off the door push a small metal piece inside the lock from the back to push out the broken key. If unable to take it off, get an old windshield wiper, remove the stainless steel supports from the wiper (long skinny piece of metalt holding rubber blades in place). Grind or file an angled tooth into the end of one. Insert into lock (tooth down) so it catches on the teeht of ghe broken key, pull rod and key out.
Amerock Hardware... | Answered on Aug 29, 2014
You will have to carefully drill them out. Start with a small bit and slowly work up to a bigger one as you go once most of the head is drilled out the latch should pull off, you can then use vice grips to unscrew the remaing part of the screws.
Amerock Hardware... | Answered on Aug 11, 2014
25.4 x 5
Remove lock from door.The round part contacting door usually spins to accommodate different width doors. This will pull the assembly together.
Amerock Hardware... | Answered on Jun 25, 2014
If you want to clean or polish your copper cabinet hardware, there are few way to go, like cabinet hardware (Knobs & Pulls) which you believe are copper it's really zinc casting with copper plated.on which is applied a thin coat of polish to prevent oxidation, and that plate about two atoms wide and any sort of a harsh or chemical clean on it will wipe out it.
The finest thing you can follow is to take a jewelry polishing rag and go over the Cabinet hardware a bit. However, I don't see that it is offensive to have a copper pull that has turned color and has a "patina" on it. That is sometimes viewed as beneficial in decorating.
The zinc pulls with copper plating are made so after few years replaced with new pulls.
Amerock Hardware... | Answered on May 30, 2013
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Hardware &... | Answered on Jul 25, 2020
It's important to make sure everything is okay with your boiler. That means that it turns on and works just fine when you want it to, and in the same way it should also turn off when it needs to be turned off.
Boilers not turning off might not be a problem in your home but there certainly are some homeowners who struggle with this issue. This issue needs to be fixed right away because boilers that won't turn off could increase the risk of overheating in your home. Not only that, but you'll also find yourself paying more since your boiler won't stop running.
You can check your boiler's thermostat and see if anything changes when you try to turn the temperature levels down. If nothing happens, you should contact an expert to check the thermostat. Hiring an expert offers many advantages. Your heating system professional will also look for other areas that could be causing the issue such as the valves, the programmer, and the intricate wiring inside the boiler. These areas require the skill of an expert that's why it's best to visit the website of I-Delta to get connected with a professional who will help you.
Hardware &... | Answered on Jul 11, 2020
Amerock Double Magnetic Catch - White AM-M07-03941-664 Logo
2 questions posted
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Amerock Hardware & Accessories
Most Popular Question
install magnetic catch in cabinet
  • Hardware & Accessories
