20 Most Recent
U-Line U Line Echelon Series CLR2160 15'' Clear Ice Maker with 30 Lbs of Ice Storage 60 Lbs Daily Ice Production Drain Required Questions & Answers
The unit does not seem
I would remove the bottom panel and clean the condenser coils using foaming coil cleaner to pull out the deeply embeded particles of lint and dust.. I would get some nickleguard ice machine cleaner and go by package directions. I have a late model clear ice manual. If the coils are clean and you have cleaned it up good and still have problems you could have a faulty thermistor (page 16).
Troubleshooting starts on page 22.
CLEAR ICE MAKER SERVICE MANUALI recently worked on an
older model Scotsman undercounter ice machine. It was low on gas and so I accessed the the suction line with a saddle valve and added some to it. If you decide to go that route after doing everything else first then be very careful about adding any gas to that machine. It is best to weigh in the charge. Ice machines are very fickle and can be tricky to service. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Clrc02075s
yes turn the rocker switch but you cant use it as a refrig this cuts compressor and all off
I have a U-Line CLR2060 undercabinet ice maker.
The storing compartment is not refrigerated so it will melt away the warmer ambient temperature the faster it will melt . also make sure there isn't something producing heat in the compartment
U line wcm 45 head unit removal.
The thermostat does come through the back of the unit and pushes into a tube attached to the ice mold , I do belive they are still available
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
