20 Most Recent
W87-Rh-P Rapide Ultimate Clean Upright Carpet And Upholstery Washer Questions & Answers
Changing brush motor wiring colours
or heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
Vax instructions
Check the seal on the water/soap container to see if its clean and re-seat container.
Won't start
This could be the micro switch under the start pedal, I had a similar problem with a VAX hover, if you can send it to VAX if its still under warranty, if not you could buy a switch online and try it although without testing its a small risk and also with invalidate warranty. I use this site for spares. http://www.spares2you.co.uk/Vacuum_Spares/Vax_Spares/?gclid=CLmj9IzW-LoCFRMftAodwQMAbQ&#.VOxTUS6SjFV
My vax rapide w89 will not spray water from the bottom
Hi s_hall9800,
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
How do I gat fluff out of shampoo cleaner
Don't use a shampoo cleaner. All soap is a Lubricant so instead of using a Shampoo try IVORY soap or Irish spring Or that HUGE old school bar of soap its Light GREEN & used to help poison ivy =you may have to soak the Bar of soap over night but a water softner keeps soap from creating bubbles & a water softner is only salt added to water so add a table spoon to 1 gallon to IVORY or DOVE or IRISH SPRING it cant hurt its only soap
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
