20 Most Recent 08 09 10 Santa Fe Veracruz 1 Tire Pressure Sensor OEM 52933 2G200 Questions & Answers
Dash lights out restarted when removing start relay in fuse box and plug in again is this the problem
Tire Pressure Monitor Systems TPMS, that amber tire and exclamation point light that comes on in your dash advises you if you have a tire with low pressure. If it's on, check the pressure in ALL of your tires to ensure they ALL have the right pressure in them, and if not, then fill them to the proper tire pressure as listed on the placard on your drivers door or door frame. The sensors in the rims transmit an rf signal to the TPMS computer and if it senses one of the tires as having too little pressure, then the light comes on. Some vehicles have to have the system relearned if a sensor has to be replaced, and some if something as simple as having the tires rotated or adjusting the pressure require relearning. The sensors are battery powered and have an expected life of 10 years or 100,000 miles, then they will need to be replaced with new sensors. (Unfortunately the batteries are not replaceable). They can cost upwards of $150.00+ per sensor, and with installation onto the rims and retraining to your cars computer, may very well exceed $200.00/tire, depending on the initial cost per sensor of course. Also, there is no way to determine if one is bad without having a TPMS relearn tool handy. They can run upwards of $1000.00+. So basically, this isn't a job that just anyone can attempt by themselves, and will require a trained individual with the proper tools to attempt. But I would first off suggest if you haven't checked your tire pressures, check them and adjust to the proper inflation pressures. It's fine to go a couple pounds above the manufacturers recommended pressure, just in case you have a very touchy sensor that goes off if the tire pressure goes a little as 1/2 pound low. Also, if a tire is low for an extended amount of time, the sensor may go into what's called "Sleep Mode" where it will actually turn itself off until the pressure issue is resolved. Incidentally, the light on your dash will still be on. To turn the sensor back on may require driving the vehicle at a minimum of 20 mph for at least 20 minutes. If adjusting the tire pressure and driving the vehicle does not turn the light off, then you will most likely have to have the system serviced and new sensors installed, or at least have the sensors relearned to the computer. Also, even brand new sensors may go bad sooner than 10 years or 100,000 miles depending on how old they are when they are installed in your vehicles rims. If some older stock sensors were installed in the rims, then life expectancy may vary. Good luck.
3/7/2015 5:11:52 AM • 08 09 10 Santa... • Answered on Mar 07, 2015
Code p0700 for hyundai elantra 2010
looks like it's hard to get.. why don't u try online some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
1/28/2019 9:57:59 AM • Hyundai Vehicle... • Answered on Jan 28, 2019
We recently purchased a 2007
Hi, My 2012 Cadillac SRX did the same thing to me last year. I replaced the battery in the remote and it fixed the problem. The old battery wasn't strong enough to trigger the proximity sensor on the car. Click on link below. I hope that will fix yours. HYUNDAI 5WY8740 EN Factory OEM KEY FOB Keyless Entry Remote Alarm Replace
6/26/2017 7:38:07 PM • Hyundai Vehicle... • Answered on Jun 26, 2017
Heater doesn t blow hot air passenger side
Vents are vacuum actuated. check all vacuum lines for cracks or broken
10/9/2014 4:31:08 AM • Hyundai Vehicle... • Answered on Oct 09, 2014
My 2006 azera heat dual control blows cold air on passenger side.
Need to have the passenger side air control sensor Checked it is most likely stuck in the last position probably air condition..Hope this helps..good luck..
10/3/2014 7:55:30 PM • Hyundai Vehicle... • Answered on Oct 03, 2014
Oil pressure switch leaking
Try tightening but be careful it can break..if sill leaking replace it..any auto parts store carry or can order them.not a bug job..good luck..
10/3/2014 7:10:54 PM • Hyundai Vehicle... • Answered on Oct 03, 2014
Replacing oil pan gasket
you gotta drain the oil then drop the oil pan clean old gasket off and oil replace the gasket and reinstall oil pan put oil back in and after checking the oil level or changing oil you are ready to go
9/9/2014 3:13:21 AM • Hyundai Vehicle... • Answered on Sep 09, 2014
Hyundai dealer says battery is corroded but I see no evidence only a little black on top of battery?
I think you can try to use GDS VCI Diagnostic Tool to diagnose it, Then you can found the problem. V15 GDS VCI Diagnostic Tool for Hyundai & Kia From http://www.careucar.com/wholesale/gds-vci-diagnostic-tool-for-hyundai-kia.html. GDS VCI Diagnostic Tool is an advanced service system that provides comprehensive coverage for all Hyundai vehicles including all Hybrid cars. GDS provides complete diagnostics, analysis and reprogramming capabilities as well as a huge library of technical, service and repair information. And now buy it, you can get NEW kia GDS software free. 60a98640-31d6-491d-9ecc-24a77606fc1c.jpg
8/19/2014 7:27:44 AM • Hyundai Vehicle... • Answered on Aug 19, 2014
Hyundai Getz misfiring
Have you diagnosed the car for error codes? Upon reading your question I first thought about the HT leads anp plugs. You replaced those. Next step is to suspect dirty (clogged) fuel injectors. Pour a whole bottle of a good fuel injector fluid into almos empty fuel tank. Then add ONLY 2 gallons (8 liters) of fuel. Drive car around like "you stole it". Try to floor it or fully accelarate in 2nd gear as mech as you can, revvin ebgine above 4000 rpms. If there was any dirt, varnish or clog in any injector, this procedure should fix it in a day or two. Still do get an error code diagnosis as soon as possible. You may be surprised about what sometimes comes up.
7/19/2014 1:50:14 PM • Hyundai Vehicle... • Answered on Jul 19, 2014
WHERE IS THE FUEL PUMP IN HYUNDA SONATA
It is inside the fuel tank. It is one of a three part assemby device that goes inside gasoline yank. This assembly is composed by the fuel filter, fuel pump and fuel level gauge sending unit. It is serviceable ONLY by qualified mechanics under very specific safety conditions.
7/19/2014 1:33:00 PM • Hyundai Vehicle... • Answered on Jul 19, 2014
P0115
Engine Coolant Temperature Circuit Malfunction Possible causes - Low engine coolant level - Faulty Engine Coolant Temperature (ECT) sensor - Faulty engine coolant thermostat - Engine Coolant Temperature (ECT) sensor harness is open or shorted - Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
5/26/2014 4:28:40 AM • Hyundai Vehicle... • Answered on May 26, 2014
Rpm goes up and down on my hyundai tiburon
Air leak somewhere or the Air flow sensor is faulty.
1/6/2014 12:23:56 AM • Hyundai Vehicle... • Answered on Jan 06, 2014
2answers
Hi , I have a problem . Hyundai getz 1.3 the car
have you changed the plug leads. or the ds pack some engines have leads or a dispack. dispack the seals can go and cause arking. leads weak leads will sort out in them self and moving them about can reconect them. if they have gone hard they should be changed as that means they are brital.
10/18/2013 4:38:58 AM • Hyundai Vehicle... • Answered on Oct 18, 2013
My accent car's clutch pedal becomes loose at every time running i have changed clutch plate and adjusted the pedal but still it shows problem
Did you bleed the air out it's just like the brake sys it has a bleed valve to get the air out
5/17/2013 11:39:48 PM • Hyundai Vehicle... • Answered on May 17, 2013
Does Hyundai veloster have standard security system
The Veloster may or, may not have a manufacturer installed security system. However, what the salesman is trying to sell you is an aftermarket vehicle security system at an inflated price. The vast majority of new car dealers sell aftermarket alarms and remote starters that are installed by an outside company that has a contract with the dealership. These same systems are available at various shops at retail price. The dealership talks you into buying these products by telling you that if you buy it from someone else that your manufacturer warranty will be voided. This is not true. Read magnusen-moss warranty act. I know this because I was the in house installer at several new car dealerships, installing alarms. remote starters, dvd, back up sensors, navigation systems, stereos, etc. for over seven years.Now, with that being said, not all retail aftermarket shop are the same. Do your research. Read what others have to say about these companies before making a decision to have them install something on your nw vehicle.
1/27/2013 6:07:42 PM • Hyundai Vehicle... • Answered on Jan 27, 2013
2answers
I need to know which
cylinder 1 is the one closest to the timing belt and fan belt
12/11/2012 12:11:19 PM • Hyundai Vehicle... • Answered on Dec 11, 2012
0answers
Oil pan gasket hyundai what do i need
You need a floor jack. A jack stand or two, oil catch pan and probably a 15 millimeter socket (socket size may be wrong) and an oil pan gasket. Go to a parts store an let them know what vehicle you have and a replacement gasket should not be more than 20 bucks.
11/13/2012 1:53:49 AM • Hyundai Vehicle... • Answered on Nov 13, 2012
08 09 10 Santa Fe Veracruz 1 Tire Pressure Sensor OEM 52933 2G200 Logo
1 questions posted
Top Hyundai Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Vehicle Parts & Accessories
Most Popular Question
dash lights out restarted when removing
  • Vehicle Parts & Accessories
