20 Most Recent
Minolta AF102 35mm Point and Shoot Camera Questions & Answers
Film
I am guessing that the film is supposed to wind itself on when you close the camera? If you open the camera you may see that the film "leader" has not been drawn into the camera. When you load the film pull a small amount of the film (1 or 2 inches) out from the canister and place it into the (usually) right hand side of the camera where you will see the gears waiting to engage in the sprockets to pull the film in. The film should also lay flat across the rear of the camera where there are gears top and bottom that should engage with the film.Also check you have fresh batteries.
Minolta 404si Dynax doesn't shoot
It sounds like you may have an issue with the shutter mechanism, most likely caused by a worn out or dirty shutter. I would recommend taking it to a professional camera repair shop to have it checked out. They may be able to diagnose the issue and repair it or, if necessary, replace the shutter.
If you are not comfortable with taking it to a professional, you can try to diagnose the issue yourself by taking a few test shots with the camera on a tripod in different lighting conditions. If you are able to get some consistent results (e.g. the shutter always fails to fire at the same point or in the same lighting conditions) then you may be able to narrow down the problem and focus your troubleshooting efforts.
Al 1000 manuals
Most lens have a red spot on them. There is usually a red spot on camera (look on left side). The one on camera body is the unlock and needs to be pushed and held in as you rotate lens red spot towards the camera spot. When they line up you can remove lens. ?
What card does my Minolta DiMAGE 1 use
The answer to this, and many other questions of a similar nature, may be contained in the manual. If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
