20 Most Recent Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Questions & Answers
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
Sears Genie... | Answered on May 04, 2017
UNPLUG RHE UNIT WAIT ABOUT 5 MIN. AND PLUG IT BACK IN.
THIS RESETS THE SEQUENCER.
SOMETIMES IT WILL SOLVE THE PROBLEM.
HOPE THIS HELPS
Sears Genie... | Answered on Oct 28, 2016
It sounds like you may have a problem with the eyes at the bottom of the door jam. These two eyes must be aligned so the light from one is picked up by the other one. Sometimes they get bumped by accident and need to be re-aligned. Check at the top of the eye where it is touching the metal bracket. If it has been moved the plastic pin on top of the light sensor will be out of the hole in the metal bracket. carefully move the plastic light body until it snaps into the hole on the metal bracket. Then try the remote. If that doesn't work, check both boxes on each side of the garage jam. one should send out a light beam and the other one should receive it. Try this. In the dark put a piece of paper in front of the unit that is NOT sending out light the beam. Line up the light beam with the receiver hole on the side of the unit. move it around until it shines into the eye on the side of the other unit. Try the opener. See if solves your problem. If I get to a point like this where nothing I try works I get out a tool that always fixes anything, my checkbook. Good luck. :)
Sears Genie... | Answered on Apr 27, 2016
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Sears Genie... | Answered on Mar 18, 2015
The garage door will only go down by holding the button on the wall switch
Sears Genie... | Answered on Jul 20, 2014
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Sears Genie... | Answered on Jul 05, 2013
Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Logo
33 questions posted
Top Sears Building Materials Experts
Mike
Terry Smith
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Sears Building Materials
Most Popular Question
want program genie ecellerator isd 1000
  • Building Materials
