20 Most Recent Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM 16MB Cache SATA 30Gbs 35' 1 TB SATA II Hard Drive Questions & Answers
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart you will have to have master with slave set up you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive IDE-0 means Pri master ?IDE-1 means Pri slave ?IDE-2 means Sec master ?IDE-3 means Sec slave ? if you need more help with this post a reply Hope this helps
Samsung... • Answered on Aug 18, 2011
Check power connector of hard disc is in correct socket. Check if there is 5V and 12V in power connector.Try to replace SATA cable of your hard drive. If your hard drive is still not appear on your computer try to determine if your motherboard is already installed the sata software of your motherboard.
Samsung... • Answered on Jul 13, 2011
Many, many, years ago, motherboards did not support any disk-drive larger than 8GB.
Is this the first time that you have tried connecting your 1000GB disk-drive to your computer?
Samsung... • Answered on Apr 02, 2011
The instructions for the Samsung BP59-00107A remote will be in the manual for a TV that came with the remote. Compatible TVs include the HLS4266WX rear projection DLP. Crutchfield has the manual for this TV on the product page: https://www.crutchfield.com/S-kOiJWjEvD7P/p_305HLS4266/Samsung-HL-S4266W.html . Look below the What's in the Box header to find the link. The current link is https://pdf.crutchfieldonline.com/ImageBank/v20060727152300/Manuals/305/305HLS4666.PDF . Start reading from page 26 (Operation). The section for setting your remote to work with other devices starts on page 34. A more concise guide to the remote and the code lists starts on page English-2 (page 134 of the PDF). I hope this helps. Cindy Wells
Samsung... • Answered on Jul 10, 2021
Edited question to translate from Text Speak to Written English :>) This is called screen mirroring and is easy when you have a smart television connected to your home network. There are videos and text based articles in the link. I reversed the Search Query to 'Connect my Samsung Android Tablet to my Bush TV', as I presume that is what you meant, because you want to see a bigger screen. https://www.google.com/search?q=App+to+connect+Samsung+Android+tablet+my+Bush+LED+tv ..
Samsung... • Answered on Jul 02, 2021
You cannot always tell if a capacitor is bad by looking at it. If it is bulging or leaking or has blown out, that would be obvious but, there are increases in resistance internally called ESR and there are dielectric leakages and that you cannot see. These failures require special equipment to detect.
Samsung... • Answered on Jun 06, 2021
we can not guess on a price as we do not do that type of thing here on the forum
Samsung... • Answered on May 01, 2021
To download songs just go to the website from where u want to download song then there should be download button around a song to download.Just click on it and your download starts.
thanx
Samsung... • Answered on Mar 31, 2021
1 Turn on the computer, then press the F4 key several times before the Samsung logo appears to open Samsung Recovery. 2 Click Computer Factory Reset 3 Click the Start Factory Reset button. 4 When the Start reset confirmation screen appears, click OK. 5 Your PC is reset. (Please note: resetting may take some time, depending on your PC.) 6 When a message appears saying reset is complete, click the OK button. 7 The PC will restart. 8 Finish setting up your PC according to the on-screen instructions. 9 After rebooting, check that your PC has been reset correctly.
Samsung... • Answered on Mar 27, 2021
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Samsung... • Answered on Mar 08, 2021
check junk folder , check spam folder smart tv uses what system ? google android ? download app to tv from playstore if android system ??
Samsung... • Answered on Feb 12, 2021
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue. I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.) On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates. I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem. Cindy Wells
Samsung... • Answered on Oct 20, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily cheaper that new modems and routers
Samsung... • Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port? If so then try and plug it in that way. Try and reset the router and tv Make sure the connection settings are correct or defaulted Are you entering the correct password? Are you close enough to the router? reset the network setting on the tv it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail. Mr.Mike
Samsung... • Answered on May 20, 2020
Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM 16MB Cache SATA 30Gbs 35' 1 TB SATA II Hard Drive Logo
3 questions posted
Top Samsung Computers & Internet Experts
Ekse
Oloyede Monsuru
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Spinpoint Samsung
  • Spinpoint Samsung
Most Popular Question
2 hard drives want make one master
  • Computers & Internet
