20 Most Recent
Logitech X530 5 Speakers Questions & Answers
My logitech x530 speakers are not playing
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
HOW DO I GET ALL
I presume you have a sound system (surround ) dvd etc the speakers are usually connected at back these are all colour coded so should be no problem hope this helps you cheers
Logitech X530 subwoofer buzzes when powered on
this is normal. most strong but non-professional sound equipment has a low frequency buzz to it, especially if there's a router/cellphone/microwave near by. This is an electronics issue, when the output impedance (speaker resistance) gets in sync with the input impedance of the built in amplifier and you get a sort of a sygnal loop, just as it happens on concerts, when the mic is placed directly in front of a speaker, at a certain distance, so the output syncs with the input. What's important is to have clear sound on all speakers. If you have buzzing sound even with all speakers plugged in and playback is on, then you'll need to check the power cord, the audio cables, and also the sound card's output settings. Sometimes, especially if we're talking about an on-board sound adapter, the output quality is far from perfect, and good speakers are all too good to show any inperfection. I'm afraid the only way to have a zero-level input for audio amplifiers is to cash out several hundred bucks for the amplifier alone, and another thousand for the speakers.
If you found this post informative and helpful please vote for it with a Thumb Up. Thank you.
