20 Most Recent JBL Creature III 2 Speakers Questions & Answers
Speakers were working great for
it might b ethe wireing of the speakers
4/19/2017 7:04:12 AM • JBL Creature III... • Answered on Apr 19, 2017
JBL Creature III 2.1 speakers can only get very low volume on left speaker
The pre-amp is defective. Get them replaced.
7/11/2015 5:22:51 AM • JBL Creature III... • Answered on Jul 11, 2015
Volume control keys on my jbl creature 3 speakers are not working what to do
If you remove the knob and Put a very small amount of WD40 down at the base this can help clean and lubricate the Knob inside. This sometimes cures the problem. If not the volume knob will need to be replaced i included a link to a page that shows The knob and it is just 2 wires. The volume knob can be picked up at a radio shack.
9/29/2014 7:35:35 AM • JBL Creature III... • Answered on Sep 29, 2014
Just moved and was disappointed
It must be a power adapator problem. Most of the power adaptors do not have a indicator to show you if its working. Is the power indicator on the subwoofer module working if not I am right about the adaptor.
8/31/2014 7:15:23 PM • JBL Creature III... • Answered on Aug 31, 2014
I can't seem to get the volume up button to respond
Its a touch button. Don't tap it. Just keep your finger on it and you should hear the volume increasing.
9/21/2013 9:32:46 AM • JBL Creature III... • Answered on Sep 21, 2013
Where to Find my Serial Number?
The serial number is at the bottom of the subwoofer.
9/21/2013 9:30:36 AM • JBL Creature III... • Answered on Sep 21, 2013
The green light is on.. but no sound
Which operating system ???... Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it. Click start control panel sounds and audio volume advanced speakers make sure you have selected the ((appropriate speakers)) also audio you will find 3 drop down lists make sure you have the correct settings there also try swapping the speakers around if the problem still persists either the speaker is faulty or the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor or a can of compressed air making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
9/12/2013 6:57:16 AM • JBL Creature III... • Answered on Sep 12, 2013
0answers
Creature 3
Be the first to answer 10/22/2012 3:57:24 PM • JBL Creature III... • Posted on Oct 22, 2012Be the first to answer
JBL Creature III 2 Speakers Logo
33 questions posted
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Audio Players & Recorders
Most Popular Question
find serial number
  • Audio Players & Recorders
