20 Most Recent Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Questions & Answers
There is a wiring harness plug on the back side of the PTO switch, simply remove the plug, squeeze the two tabs holding the PTO in the dash and slide it out the front side. Reverse for install. ** Disconnect battery cable to be safe.
Husqvarna Riding... | Answered on Dec 12, 2017
There is a main fuse and some relays up under the dash board it is an auto motive style fuse
Husqvarna Riding... | Answered on Aug 28, 2017
Disconsolate the connector from the clutch. Engage the clutch circuit and see if electrical circuit still response as if shorted.
If the response is the same check wiring, switch and relay. Replace/repair defecrive component.
If the response is no problem check the clutch. Inspect the connector at the clutch for broken failed wire connection. Using an ohm meter check for short. The expected resistance is about 3 -4 ohms. If the resistance is less then 1 ohm the PTO clutch is bad. Sorry. It is the solenoid coil has an internal short. Confirm if the clutch is still in warranty.
Check for after market sources for reduced price!
s-l1600-ye4zlyuovxg25rnpc03q42bj-3-0.jpg Hope this helps?
Husqvarna Riding... | Answered on Jun 23, 2017
This is not something for the novice. The clutch, if not properly installed or repaired can explode and cause personal and property damage. I would suggest the authorized dealer to make this repair.
Husqvarna Riding... | Answered on Feb 22, 2017
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Husqvarna Riding... | Answered on Aug 02, 2015
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
Husqvarna Riding... | Answered on Jul 14, 2015
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
Husqvarna Riding... | Answered on Jun 15, 2015
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
Husqvarna Riding... | Answered on Sep 20, 2014
I have a Robin or as they call it now Subaru engine with this same problem when it stopped the petrol flow into the crankcase. The fuel tap close it when finished and put the engine on TDC then no problem anymore. Check the tap if it REALLY closes as tge only other problem I had was dirt in the carburettor. I cured this with an inline fuel filer
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Husqvarna Riding... | Answered on Aug 30, 2014
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Husqvarna Riding... | Answered on Aug 29, 2014
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
244 questions posted
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
yth2448 when engage mower
  • Garden
