20 Most Recent
Toro Power Lawn Mower Questions & Answers
Toro 22" Recycler Vibration Problem
Disconnect the spark plug for safety reasons. Turn the mower on it's side, carburetor up. Slowly turn the blade by hand. You should notice if it is bent. Remove the blade. It is usually a 9/16 in bolt. Use a straight edge to determine if the cranksaht is bent. If the deck is good, you can find a used engine that bolts on. Otherwise you can use it for parts.
Toro Timecutter rapid clicking when starting.
If the rapid clicking is coming from the solenoid or starter, it sounds like your ignition key switch is broken internally. Something is making and breaking the starter connection due to the vibration of the engine running.
Gov and throttle linkage
gov. rod hooks to the hole in the top of the butterfly. the spring hooks to the carb and the front of the engine on the metal tab.
