20 Most Recent Ledu Corporation Swing Arm Lamp 34"H 100W Incandescent Bulb Clamp BlackLEDL502BK Questions & Answers
home depot should have a switch
Ledu Corporation... | Answered on Feb 28, 2019
which type of clamp did you need?
Ledu Corporation... | Answered on Sep 16, 2016
The narrow blade is the hot or black wire and the wide blade is your neutral neutral. Use an ohm meter, connect one of the ohm meter probe on the wide blade and the other meter probe on the end of each wire. which ever one gives you a reading is the neutral or white wire. You may want to next time, label the wires before you disconnect them.
Ledu Corporation... | Answered on Dec 30, 2014
Please. If it is difficult for you to find out without any instruction, how difficult could it be for someone not seeing an instruction and not seeing the lamp? Perhaps you did give us a brand, but surely not what model.
Ledu Corporation... | Answered on Jun 26, 2014
I have the ALCK 487 (mini clock I can stick to anything, since it has a backing strip) and I can't remove the function that makes it bleep every hour on the hour
Answer: Press and hold "S". If you see the seven days of the week, press "M" to erase them. it will stop beeping every hour
Home | Answered Yesterday
Much depends on the type of cistern fill valve and where the knock is emanating from but generally the cause is wear in the valve operating mechanism resulting in a tendency for it to "dance" or oscillate while filling which causes the closing of the valve not to be "clean" or instant.
This causes a series of pressure waves in the supply pipe which if not well secured along it's length will move a little causing the knock(ing) or even a buzzing sound.
This can be more pronounced when the water pressure is high and the cistern being filled at high pressure can create powerful swirl and ripple currents within the cistern causing further wear and oscillation.
Some types of valve such as the Torbeck diaphragm type is not really suitable for a high pressure fill and these are supplied with an in-pipe restrictor to reduce the flow, thus overcoming some of the problems. Most people choose not to fit the restrictor.
Home | Answered on Jan 17, 2021
That happens in every house. Do you have a thermostatic valve? If you do, it probably needs replacing. If you don't, you can fit a booster pump to hot and cold supply to the shower to keep the pressure constant.
Home | Answered on Jan 14, 2021
Remove the pendulum give the side a gentle tap. The pendulum carrier should move very fast and wind it down pretty fast.
Home | Answered on Jan 04, 2021
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Home | Answered on Dec 30, 2020
What happened to your screen? Different problems, different solutions
Home | Answered on Dec 24, 2020
call a local plumber
Home | Answered on Dec 19, 2020
Ledu Corporation Swing Arm Lamp 34"H 100W Incandescent Bulb Clamp BlackLEDL502BK Logo
6 questions posted
Top Ledu Corporation Home Experts
john h
Tom Chichester
Are you a Ledu Corporation Home Expert? Answer questions, earn points and help others
View Most Popular
  • Ledu Corporation Home
Most Popular Question
old clamp
  • Home
