20 Most Recent Petmate Booda Buddhas Doggie Large Questions & Answers
Not as much as cats.
6 Reasons We Love Dogs - Dogtime
dogtime.com > sponsored > 38115-6-reasons-love-dogs
Dogs are kind, loving, and compassionate - they forgive everything and never hold a grudge. No matter what a dog is doing, they are always present in the moment. If you watch your dog throughout the day you'll find that your dog is a better person than most humans.
The Psychology of Why We Love Dogs - Moments of Passion ...
medium.com > moments-of-passion > the-psychology-of-why-we-lov...
Mar 22, 2019 - But still the question remains, why do we love dogs so much? After a brief history of the dog (to help us understand them), this story seeks to ...
Why Dogs and Humans Love Each Other So Much ' Time
time.com > Ideas > Psychology Jul 20, 2018
You speak dog better than you think you do. You may not be fluent; that would require actually being a ...
Why Do We Love Dogs So Much? So, So Much?
www.patriciamcconnell.com > theotherendoftheleash > why-do-we-lo...
May 6, 2019 - I knew it would be awful. Just not that awful. Now that I am no longer in danger of drowning, I can't stop wondering why we love our dogs so ...
Why do we love pets? An expert explains. - The Washington ...
www.washingtonpost.com > news > animalia > 2017/11/03 > pets-are...
Nov 3, 2017 - Dogs and cats have helped us evolve into the humans we are today. ... on dog and cat behavior led him to conclude that he would never fully ...
Dogs | Answered on Jun 28, 2020
WE HAVE NO IDEA WHAT A DOG FOOD COMPANY SELLS AS WE DO NOT DO THE SEARCHING FOR YOU
Dogs | Answered on Jun 10, 2020
Onions can cause more damage to your dog than just bad breath. This pungent culinary favorite might add flavor to your dishes, but it contains a toxin that can cause serious complications for dogs.
Symptoms of onion toxicity in dogs If you think your dog may have eaten onions, there are a few symptoms of anemia to look out for:
  • Lethargy
  • Weakness
  • Decreased appetite
  • Pale gums
  • Fainting
  • Reddish *****
Treating onion toxicity in dogs The most important thing you can do, as a dog owner, to treat and prevent onion toxicity is to never allow your dog to eat onions. If your dog is suffering from toxic effects, she will probably require veterinary attention. Your veterinarian may induce vomiting, depending on how recently your dog ate the onions, and will offer supportive care until your dog's body can produce enough healthy red blood cells to replace the damaged ones. In severe cases, your dog may require a blood transfusion.
Dogs | Answered on Apr 24, 2020
Since you asked a general question, it
depends on the breed. ie: Maltese 15 years life expectancy but it depends on their health growing up.
Dogs in the wild need a safe haven and they usually seek out a place where they can call their own. If a domestic dog has no particular place to hide it will usually go under a table or stairs to shelter itself. So no using a dog crate is not cruel and it is a great way to house train your pet.
Dog owners tend to dismiss bad dog breath as just "dog breath," but there is usually a very good reason behind the odor. The most common causes of bad breath in dogs are bad oral hygiene and periodontal disease.
https://www.akc.org/expert-advice/health/get-rid-of-stinky-dog-breath/
Apples are wonderful to use as treats for a dog. They can be healthy for the dog to digest. Theirfor swallowing apple seeds can harm dogs.
Tip
Why You Shouldn't Swap Small Clipper Blades Between Dog Clippers
Although dog clippers manufacturers claim that their clipper blades are universal (fit other dog clippers), they work best on the dog clippers they were designed for.
The socket (clipper blade), the hinge assembly and blade drive assembly (dog clippers) vary from manufacturer to manufacturer. If you are using different brands of clipper blades on different brands of dog clippers, there will not be a perfect fit.
HINGE ASSEMBLY
The hinge assembly secures the clipper blade (via the blade socket) to the dog clippers.
If the hinge assembly is not regularly replaced, your clipper blades will start to rattle on your dog clippers. The ears on the clipper blade socket are constantly rubbing against the metal hinge assembly, which consequently causes wear on both the socket and hinge assembly. You must ensure that there is a snug fit between the clipper blade socket and the hinge assembly or the blade will eventually rattle.
On average, if a groomer is clipping 8 dogs a day, the hinge assembly will probably need replacing every 12 weeks.
When replacing the hinge assembly, make sure that the screws are secure because if they are too loose the clipper blade will not cut correctly or not at all.
It is not advisable to try to adjust the ears on the socket to enable the clipper blade to fit the hinge assembly, because you will risk breakage which will render the blade redundant until you get the socket replaced by a sharpening professional. The best person to adjust clipper blade sockets is an experienced clipper blade sharpener because he has the relevant tools and should the socket snap, he has spares.
BLADE DRIVE ASSEMBLY / BLADE LEVER
The plastic lever on the blade drive assembly locks into the cutting blade and drives it backwards and forwards.
Problems occur because the black plastic lever is constantly rubbing against the metal cutting blade; so consequently, the plastic will gradually wear away. Once the lever is worn, the cutting blade won't be driven side to side as much as it should.
If the blade drive assembly is not regularly replaced, the clipper blade will leave tram lines in the coat, pull at the hair, the dog clippers will sound noisier and the clipper blade will eventually, stop cutting.
On average, if a groomer is clipping 8 dogs a day, the blade drive assembly will probably need replacing every 6 - 8 weeks.
If your blade drive assembly is worn, your newly sharpened blades will not cut because the cutter blade is not being pushed along the whole width of the clipper blade (it is more noticeable on blades where the teeth are further apart - 3,4 5 & 7). If this is the case, we would strongly recommend that you replace your blade drive assembly.
on Feb 28, 2020 | Dogs
Although Canine Carry Outs has never issued a recall, we have serious questions regarding the safety of ingredients used to produce their dog food products. In addition to propylene glycol, Canine Carry Outs also adds artificial food coloring dyes and artificial preservatives into all of their treats.
You might find the below link interesting...
https://www.pawdiet.com/pet-food-recall/canine-carry-outs-recall-history/
Dogs | Answered on Dec 11, 2019
A dog can go without food for a few days and then will eat when it is hungry. Just stop giving your dog your food and at its normal feeding time give it a bowl of its food. If it does not eat it, take the food away. Then 24 hours later put the bowl of food out for the dog. If it has not eaten it within ten minutes take it away and then 24 hours later put the bowl of food out for the dog again. By now the dog should be happy to eat what it is given.
Dogs | Answered on Oct 26, 2019
Nothing,if the dog is having problems see a vet,
Dogs | Answered on Oct 03, 2019
Surprisingly, unsweetened, canned pumpkin will do wonders to help with a constipated dog. Use a small amount from a teaspoon at first then go to a larger amount a day later. Dogs love pumpkin so getting it to eat some shouldn't be an issue. Pumpkin is a good source of fiber for them and will not hurt them. Go sparingly at first so they dont end up with diahrea.
Dogs | Answered on Oct 01, 2019
Bathe frequently in warm salty water and keep an eye out for any object stuck between the claws.
Dogs | Answered on Sep 28, 2019
The only info I can give you is if it tries to pass stool and nothing comes out, then that might be an indicator. Do not take it lightly though. If you see bloating of any kind this could be an obstruction which is life threatening. Some breeds are actually prone to getting constipation but usually the smaller breeds. When I raised GSP, I had to put one down as she ate half a Frisbee and the obstruction caused part of her intestines to die. I always kept dried apricots around. Give the dog no more than 3 and prunes work also. I wish you luck but observe the dog closely and your vet can also call something in to **** store.
Blessings
Dogs | Answered on Sep 10, 2019
Petmate Booda Buddhas Doggie Large Logo
0 questions posted
Top Petmate Dogs Experts
Ruth summersides
Rhonda Webster
Rhonda Webster
Thomas Perkins
Thomas Perkins
Are you a Petmate Dog Expert? Answer questions, earn points and help others
View Most Popular
Petmate Dogs
  • Petmate Dogs
Most Popular Question
buy new cover two months time wash
  • Dogs
