20 Most Recent
Gbc GLX2030 Shredder Questions & Answers
What oil do I use
You can use any vegetable based oil, but...I highly recommend shredder specific oil as it has additives to prevent the paper dust and shreds from clogging and gumming up.
Hi I have a GBC
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
GBC ezload laminator displays code 3 and stops after 5 seconds
When a GBC EZLoad laminator displays code 3 and stops after 5 seconds, it typically indicates an error or issue with the laminator. Code 3 is a general error code that can have different meanings depending on the specific model and manufacturer.
To troubleshoot the problem, here are a few steps you can try:
1. Power off the laminator: Turn off the power switch and unplug the laminator from the power source. Let it sit for a few minutes to allow any residual power to dissipate.
2. Check the laminating pouch: Make sure the pouch you're using is compatible with your laminator. Ensure that the pouch is not too thick or too thin for the laminator's specifications. It's also important to check if the pouch is inserted correctly and aligned properly.
3. Clear any obstructions: Inspect the laminator's feed area and remove any jammed pouches or debris that might be causing a blockage. Gently clean the rollers and ensure they are free from any adhesive residue or dirt.
4. Reset the laminator: Some models have a reset button or a reset procedure that can be followed to clear any temporary errors. Consult the user manual or manufacturer's website for instructions specific to your GBC EZLoad laminator model.
5. Test with a different pouch: Try using a different laminating pouch to see if the issue persists. This can help determine if the problem lies with the pouch or the laminator itself.
6. Contact customer support: If the problem continues after attempting the above steps, it's advisable to reach out to the GBC customer support team or the place of purchase. Provide them with the specific error code (Code 3) and a detailed description of the issue. They should be able to provide further assistance or recommend a solution.
Remember, these steps are general guidelines, and the specific troubleshooting process may vary depending on your laminator model. Always refer to the user manual or contact customer support for accurate information and instructions.
GBC Shredmaster 5270M gears are locked up
I believe your GBC Shredmaster 5270M should work after the following steps:
Check the drive belt - If the blades are not turning, the problem could be with the drive belt. To access the drive belt, you may need to disassemble the shredder. Look for any signs of wear or damage on the belt. If the belt is damaged or worn, it will need to be replaced.
Inspect the motor - If the blades are not turning, the problem could also be with the motor. Check the motor for any signs of damage or wear. You may also want to check the motor brushes to ensure they are making proper contact with the motor. If the motor is damaged, it will need to be replaced.
Test the shredder without load - Try running the shredder without paper or other material in the blades. If the blades turn, then the issue may be related to the shredder being overloaded with too much material. Reduce the amount of material being fed into the shredder at one time.
Check the circuit board - If the motor is not receiving power, it could be due to a problem with the circuit board. You may need to take apart the shredder to access the circuit board and inspect it for damage. If the circuit board is damaged, it will need to be replaced.
