20 Most Recent
Lite On LVW-5007 Questions & Answers
I need a manual
Go to Lite-on website and there under downloads you can download it
No response
I had a similar problem I simply removed the cover (about 4 phillip head screws) and the cover plate of the disk drive(just pull it off) and removed the disk.
Ensure that the drive is not jammed by moving the drawer forward as if it would when it opens.
Replace the disk cover and close the case using the phillip head screws. Plug it in again and let it boot up. Try opening the door by pressing the eject button. It should work.
This worked for me. I have a bad drive and want to replace it so I explored a bit on how to remove it.
Liteon LVW 5007 recorder problems
check with www.partstore.com and see if you can get a manual for your dvd recorder.i cannot tell off hand what to do the manual will.good luck or go to www.oxysearch.com for transfer of data.
TLX-04243B Dead set Red blink lite on right front corner
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/17/2017 7:18:32 AM •
Lite On...
Answered
on Jan 17, 2017
-DVD Door will not open :(
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
12/25/2013 7:39:08 PM •
Lite On...
Answered
on Dec 25, 2013
