20 Most Recent Lite On LVC9006 DVD Player/VCR Questions & Answers
3answers
Lost remote, need to know what code number is
A universal will not allow you to do all the things the unit does,it will let turn on and off but the menu and settings might only be accesed with the original remote.Try this http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=75
6/25/2016 1:57:47 AM • Lite On LVC9006... • Answered on Jun 25, 2016
Vhs tape stuck
eject and pull out the tape by force, then you will see some of the tape in where its hung up, cut the tape and splice back together with scotch tape, (unless it is a rented movie) then you have to take it to a repair man have it removed.
10/13/2013 7:19:05 AM • Lite On LVC9006... • Answered on Oct 13, 2013
4answers
DVD gives an invalid Disc Error
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
9/6/2012 4:42:54 AM • Lite On LVC9006... • Answered on Sep 06, 2012
2answers
Lite on lvc9006 dvd player says invalid disk it
try to clean it using the dvd cleaner disc.
9/6/2012 4:40:42 AM • Lite On LVC9006... • Answered on Sep 06, 2012
0answers
Dvd can't read dvd but works fine in all cd's
your lens of your dvd is not good need to replace it the parts 100% sure.([email protected])
3/10/2010 3:34:16 PM • Lite On LVC9006... • Answered on Mar 10, 2010
Dvd section stop working it won't read the disc
I am just wondering whether the dvd has condensation , which is stopping it working.
If you can eject the disc then turn off dvd.Take it into a warm room , turn it on and leave for 2-3 hours.
Then try again.
Well this a solution that needs to be done before looking at other programs.
12/5/2009 3:12:27 PM • Lite On LVC9006... • Answered on Dec 05, 2009
Failure in tape to disc transfer
what kind of software are you using. I have had problems with this type of transfer and I had to use a special transfer device. If you want to know about the device write back and I will tell you how I did it.
1/7/2009 4:24:08 AM • Lite On LVC9006... • Answered on Jan 07, 2009
Remote buttoms non functioning
First of all try to watch the IR LED through a photo camera, while you are pressing the buttons. If you see it pulsating, then there is nothing wrong with your remote.
This is one way to repair your remote:
1- Open it. On the back face you'll see black spots of rubber. Try to clean them gently with a piece of cloth and some isopropylic alcoohol. If you have multimeter try to check the resistance of the spots. It should be less than 100 ohms. If the resistance it is bigger I suggest you to cut small pieces of thin foil (the one use in the cigarettes packs it is excellent). Then put very small amount of super glue on the black spots and above this the thin foil. Use a tweezers. Also you can clean the PCB. Check all the soldering point. Then try it if it works. Goodluck.
1/21/2008 5:10:04 PM • Lite On LVC9006... • Answered on Jan 21, 2008
I need a remote code
I've got a Lite-On DVD recorder and needed a code to sync it with my ARCHOS system. I found that the only code that corresponded with the 'ilo' products worked...
12/19/2007 4:20:58 AM • Lite On LVC9006... • Answered on Dec 19, 2007
Manuel for LVW 1107 dvd recorder lite on
Hi Tony- I found this link to download a copy of the manual. https://www.scoop.it/topic/jtzkncj/p/4100874528/2018/08/21/lite-on-lvw-1107hc1-manual Hope this helps.
12/3/2019 1:34:21 PM • Lite On... • Answered on Dec 03, 2019
Lg60pb6650 stand lite on -turn on with remote relay clinks -screen flashes gray - then repeats -found 2nf capacitor blown on upper buffer board-tried to replace the capacitor but hard to do. Reinstall
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
8/22/2017 6:12:57 PM • Lite On... • Answered on Aug 22, 2017
0answers
TLX-04243B Dead set Red blink lite on right front corner
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/17/2017 7:18:32 AM • Lite On... • Answered on Jan 17, 2017
2answers
I am looking for parts for my liteon lvw-5055gdl
try nte.com semiconducter
1/2/2014 11:43:23 PM • Lite On... • Answered on Jan 02, 2014
Lite On LVC9006 DVD Player/VCR Logo
Popular Tags
14 questions posted
Top Lite On Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Televison & Video
Most Popular Question
failure in tape disc transfer
  • Televison & Video
