20 Most Recent
Lite On LVW-5045 DVD Recorder Questions & Answers
Can this copy DVDs to blank DVD?
Copy content from your DVD to the HDD (hard drive) - then copy content from HDD back to a blank disk. Will not copy protected DVD's. You can also download another intruction booklet for it from the Lite0n website.
Service manual
Door wouldn't open on one of those I found - the tiny drve belt at the front under the tray was limp but replacement didn't fix it. Next I tried a bigger motor pulley off an old PC drive - sometimes opened, sometimes didn't. You can remove the bezel off the front of the tray to expose the manual release, you can use a toothpick to press that - sometimes the tray eases after a while and starts working - sometimes you have to give it a shove.
Dvd tray will not open
Most dvd players have an emergency ejection feature specifically for this reason. Usually it is in the form of a tiny hole on the front of the player near the dvd tray. You can eject the disc by inserting a paper clip into the hole. I wish you luck!
Der Strom
No sound
check the optical cable hd lead or scart cable or change the cable it might be a cable break
There is a dvd in my Lite-on LVW 5045 DVD-HDD
I have had this problem before. All I did to get it to open was turn the power off and then back on and as it is coming on press the open/close button. Sometimes it takes a couple tries to get the timing right but it usually works.
Liteon dvd recorder lvw1101 starts
The Optical head unit is faulty. The disc is not being read by the head unit laser and so conveys a wrong message which ejects the cd.
Replace the optical head unit assembly but with the correct procedure.
Does'nt matter what disc i place in the player, it
can't read the disk. clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). if you are technically inclined, you can remove the top, remove the transport top, and clean the lens with a soft lint-free cloth (or a q-tip) and rubbing alcohol. wipe the lens off gently and blow it dry. the alcohol will evaporate. put it together and try again. if it still doesn't work, you'll have to replace the entire optical pickup.
Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
Lite on dvd recorder lvw-5045
the point is what was it doing before it start to do what it is doing now.kindly explain then i will be able to help you
LITE ON 5045GDL+
Common problem probably due to DVD drive gone bad. It can be replaced but not without problems
