20 Most Recent Kingston 1 Bay Data Express DE110 USB 2.0 Internal Drive Case Questions & Answers
Kingston usb 1GB
usb chkdsk utility Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box. It might take some time depending on the size of your disk but be patient. then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 you might have to alternate doing this repeatedly until you find the sequence to get the problem is resolved click start control panel scroll to folder options view place a tick in show hidden files folders and drives this may vary depending on your operating system Remove write protection to format You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control. Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions. Make sure all 3 boxes are ticked full control change and read in windows 7. Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP. Click start right click on my computer select open Right click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. Click start click on my computer to open you should see your drive right click then select format another way Click start control panel administrative tools computer management disk management Right click on your usb drive select format. If you need more help with this post a reply
11/12/2013 10:05:05 PM • Kingston 1 Bay... • Answered on Nov 12, 2013
Pen drive write protected problem
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
1/8/2010 8:08:11 AM • Kingston 1 Bay... • Answered on Jan 08, 2010
0answers
0answers
0answers
What year was house built on 31 Nolan crescent Kingston tasmania
Approximately 1984
5/12/2017 9:47:32 AM • Kingston... • Answered on May 12, 2017
0answers
0answers
Need to travel from Philadelphia area to Kingston Ontario Canada. Any suggestions?
consider a plane . train or bus ring each to see which best suits your travel plan
11/4/2016 7:12:37 AM • Kingston... • Answered on Nov 04, 2016
Kingston Kim Marie is this for real
No, it is a scam. If you respond you will be asked to send a 'fee' or provide credit card details. .
4/22/2016 4:46:26 PM • Kingston... • Answered on Apr 22, 2016
2answers
I was contacted by Kingston Kim Marie who says she is a Facebook claims agent and I have won $500,000.00 in winnings.Is this true?
No. If Kingston Kim is Nigerian, you may want to waste her time with endless, pointless correspondence, though.
2/16/2016 4:53:00 PM • Kingston... • Answered on Feb 16, 2016
Good evening how can i know what brand of usb is suported by an auto stereo tko bh-av360 i've tried with adata and kingston but it doesn't read it tanks.
Its not the hardware that might be your problem but maybe your file types.
9/8/2015 9:31:43 AM • Kingston... • Answered on Sep 08, 2015
Compatible memory card
3/14/2015 9:30:47 AM • Kingston... • Answered on Mar 14, 2015
I have kingston usb model dt102/4gbz. When I connect it to my laptop so "usb not recognized" appear and usb not working. What can I do to solve this problem. Please tell me..Thanks.
I can think of several possible reasons it's not getting recognized: 1. It's broken 2. Your OS is so old it doesn't recognize it 3. you need a driver you may be able to get from the driver manufacturer
1/20/2015 2:46:45 AM • Kingston... • Answered on Jan 20, 2015
2261 pram
2261 pram It's identified as 2261 pram usb device and not working
11/18/2014 1:23:34 PM • Kingston... • Answered on Nov 18, 2014
How to install replacement cartridge 1423 for shower
There should be instructions on the printer itself
10/28/2014 10:17:12 AM • Kingston... • Answered on Oct 28, 2014
How to fix microsd card?
lol , maybe the best way is to buys a new one , but if you have a good one and it's cost much so tell us the name of it to see what we need to do
9/28/2014 2:40:53 PM • Kingston... • Answered on Sep 28, 2014
Computers & Internet Logo
2 questions posted
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
pen drive write protected problem
  • Computers & Internet
