20 Most Recent
Pentax MX 35mm SLR Camera Questions & Answers
Hi, The side of the photo came out to be blacked
The camera needs a professional service. If you're lucky the fault is just due to gummed-up, dried-out, lubricant films but if luck is against you you'll need a new shutter assembly (highly likely). Spare shutter assemblies are not easy yo come by, so if the repairer tells you that the shutter is broken you may be better to look for another camera.
35mm SLR's are mostly worthless or nearly so these days except for a few professional grade models, so getting a replacement is not difficult if you're prepared to accept different makes/models.
Samsung S760 Digital Camera having stripes on the
Do you get the same problem when displaying pictures taken BEFORE the fault occurred? If not, then the camera has a failed imaging sensor and the only fix is to repair it (very expensive, but may be covered by warranty) or to replace the camera.
As your camera is not very old then it's worth contacting Samsung even if the warranty has expired.
Pentax MX Mirror Stuck In Up Position
This is a result of the linkage from the shutter release button being out of adjustment. It is a mechanical fault that can be repaired very easily.
Flash on all time in auto
Please, which camera model? Are we talking about the external flash or one built in? If it is built in the camera may think there is not enough light thus setting the flash to fire. That is what auto does, it takes all the decisions away from the camera operator.
11/28/2016 2:46:07 AM •
Pentax...
Answered
on Nov 28, 2016
