20 Most Recent
Tomtom Xxl 540t 5" Widescreen Portable Gps Navigator Questions & Answers
KEEP ON GETTING SEARCHING FOR RADIO SIGNAL
The tomtom traffic system uses either a 'O2 (White SIM) or Vodaphone (RED SIM). Service fluctuates between good and bad.
Contact tomtom support and ask for a replacement SIM card
Tel : 08451610009
No maps its starts up and and no maps
You will need a PC to do an update for you. Go to TomTom website and download and install "TomTom Home". Then connect your XXL540 via USB and turn it on and answer Yes when asked "Do you want to connect to Computer?". The application TomTom Home should start on your PC and it also should start updating your map. Give it a try.
How to upgraid my device?
If you're refering to upgrading your Navigation software, QuickGPSfix data and/or your current (out-dated) map, you can do it by connecting to the TomTom website (www.TomTom.com) using the TomTom HOME or MyDrive Connect software, depending on the model/version of your GPS device.
If you're refering to upgrading your GPS hardware/equipment, to have more capability/features, the device is not hardware upgradable, except for adding/using an SD card with a higher storage/memory capacity (to store more info/maps, etc.) ... provided you have a GPS device with an SD card slot.
You'll want to consider buying a newer model with more capabilities / features than what you have now.
I need to order the plastic suction cup.
If you can't find the proper one from the TomTom website ... (particularly, if the GPS device is an older version), try checking / looking for it on eBay or Amazon. Just make sure the attachment is compatible for your TomTom model.
When i turn my tomtom on i only see tomtom anf symbol
If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
