20 Most Recent
LG 32LE5300 Widescreen 32 in. HDTV Questions & Answers
Horrizontal lines
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
How to factory reset LG TV model #32LN520B. This is an LED tv.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Hair tv will not turn on or off
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Popping noise when turning on tv
if it comes from the speakers,then it may use class D amplifier and the ground somehow is there through a switch( class D is balanced GND is NOT negative to speaker).Check the grounding of the TV itself,the middle(yellow) cable.
My LG tv keeps sayig NOT PROGRAMMED
Try a hard reset first. Unplug the TV from AC mains wall socket, and re-plug it back after 30 minutes or so. This procedure must make it a hard reset. If it do not help you, be sure that its main system control memory IC is faulty. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
