20 Most Recent
LG Ally Cell Phone Questions & Answers
How to unlock an LG
You can unlock your LG Optimus One from http://www.mobileincanada.com/How-To-Unlock-Bell-Fido-LG-Cellphone, the process take around 10hrs before i get the code and cutomers service is excellent... and they can get really LG unlock code...
I forgot my pattern for my lg ally
There is no way to reset the pattern or pass code on an Android, the only solution may be to reset the phones operating system back to default or find someone local who has an android unlocking machine. Normally those machines have the capability to reset the passcode and pattern unlocks.
My touch screen on my lg ally just stopped
mos likely it is a cracked screen....even a minor crack not visible will cause it not to work........if the screen is fine then it might be loose ribbon connection or bad microprocessor or the phone is frozen/locked due to nmo more memory.....try to reset the phone.....to manufactures reset condition......if all else fails.....have the screen checked for cracked glass.....these screens have a liquid in between 2 pieces of glass and a grid template which act as a capacitor so that it responds to you touching certain co-ordinates on the screen....any cracks at all will render it useless and must be replaced, their is no way to fix the screen if it is cracked....good luck
Screen lights up but is blank
well it could have some water damage or maybe is the flex cable the one the sends de info from the logic board to the lcd...its about 5 bucks on ebay.......good luck
How to delete apps that came original to phone
I'm afraid you are stuck with them. This is a problem lots of us would like to sort out! There is one way but I would never advise it ad it would void your garantee. If you are not bothered about that though....look into "rooting" your phone. Hope this helps.
How o format lG Ally cell phone
Hi
If you wish to start your LG Ally with factory default data and settings, you can perform a hard reset on the device.
1. Power the device off. If it's frozen, pull the battery, then place it back in the device.
2. Press and hold the Volume Up, Home and Power buttons simultaneously.
3. Follow the setup instructions on the screen.
Thanks for using Fixya.
