20 Most Recent
LG GB230 Cell Phone Questions & Answers
I want diagram gb230
http://www.4shared.com/file/174298624/89aea8e5/GB230_schematics.html%29
http://www.4shared.com/get/UKfcvsjI/GB230_schematics.html
I FORGOT SECURITY CODE. PLEASE
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Iam not able to connect
hello sir,
did you activate a gprs plan on your mobile and do you have the gprs settings for your phone. If not you can get them both by calling your customer care personnel.
If you are facing further problem feel free to contact me.
And if this solution was helpful please vote it beolw.
thank you.
Why my phone lg gb230
will be not possible to update the software remotely take the mobile to your nearest service centre
I need help getting the
As your using LG GB230 cell phone it supports for internet but you have to spend a few minutes for getting internet connection settings.You just call your service provider (Vodafone, Airtel,) you have to call the customer care and tell them that you want internet connection they will tell you to send a message for some number after sending that message you will recive a settings from that number just save that settings after that switch off your cellphone.After a few minutes you switch on your cellphone.After that you just select the internet icon that you have in your cellphone.From then you start browsing.var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
How to change words like
On most LG phones, you can't do this. You just have to get into the habit of switching them out. You can only switch around the order or delete words that you've created that are not already in the phone dictionary. Sorry. Hope this helps!
Please rate my solution!
- Frankie
Keypad not working.where keypad ic
These are embedded into the VLSI board and is embedded. So it is also the microprocessor to the phone. checck to see and clean the board and the plated through holes that connect both sides of the board. it is possible that some connecions have opened on the board which means your board is faulty.
